Finding final velocity from a fall
The discussion centers on calculating the final velocity of a person jumping from a height of 25 meters while experiencing air resistance. The individual initially used the equation F=ma to determine acceleration, resulting in a value of 8.6861 m/s², and then applied the kinematic equation Vf²=Vi²+2ad to find a final velocity of 20.85 m/s. However, there is confusion regarding the correct application of forces and units, particularly in the calculation of net force and acceleration. Participants confirm that the initial calculations seem correct but express uncertainty about the accuracy of the final answer. The conversation highlights the importance of correctly accounting for forces and significant figures in physics problems.
lzh
I'm having trouble with this problem:
"A 79kg person escapes from a burning building by jumping from a window 25m above a net.
The acceleration of gravity is 9.81 m/s^2
Assuming that air resistance is a constant 88 N force on the person during the fall, find the person's velocity just before hitting the net"
So for this problem i used F=ma:
79g-88=79a
a=8.6861m/s^2
this is the correct acceleration i believe and to find final velocity i used:
Vf^2=Vi^2+2ad where d is displacement
Vf^2=2(8.6861)(25)
vf=20.85m/s
I'm using utexas's webhw service, and the answer above was not correct, can someone tell me what I'm doing wrong?
not 100% sure on this but i think:
the 79g-88N=79a is wrong the units don't cancel out properly, you know the 88N upward on the person what's the force he excerts downard?
with those two figures you can use F=ma knowing F and m to determine the actual a, and plug that into the Vf^2=Vi^2+2ad equation
I solved the problem by calculating the amount of downward force one the person; mainly his weight minus the resistance. Then I used that F in the work formula; W=FD. D would be the 25m. I got the W in Jules so I let that W = KE, which is kinetic Energy. so, W = MV^2. and solved for the desired quantity.
Same ans. So I suppose you’re ans is right.
79g is his weight, which is in N, which cancels out
but it isn't right...
I'm not sure wat u mean. But the unites do cancel out propely:
(790N-88N)/79 = a.
well N is kg*m/s^2 79kg is just the weight you're missing the acceleration (gravity)
Typo:
*79kg.
yeah g as in acceleration due to gravity
sry was distracted >.< i get the same answer as you.
are you providing the required number of significant digits?
rounding and sig figs doesn;t matter
out of curiosity; what kind of deceleration is applied form falling on the net for a safe landing. Too much would cause the person to recoil up. too little would cause he/she to hit the ground.
79g-88=79a
a=8.6861m/s^2
Vf^2=2(8.6861)(25)
vf=20.85m/s
Your method and answer look correct to me.
