Finding force and equation of motion
The discussion revolves around finding the force and equation of motion for a particle with the velocity function v(x) = ax - 2, specifically when x = a. Participants clarify that the motion occurs on a horizontal frictionless plane and attempt to derive the force using F = m dv/dt. The integration of force leads to potential energy, but the challenge remains in determining the motion of the particle over time. A suggestion is made to solve the separable differential equation dx/dt = ax - 2 to find the motion as a function of time. The conversation emphasizes the need to specify velocity and acceleration at the given position to fully describe the motion.
Jared Hill
If v(x)=ax-2, then what is its force in terms of x. What is its motion as a function of time when x=a?
What is v(x)? The motion of what are you speaking about?
Show the relevant equations and your attempt to solve the problem.
It is the motion along a horizontal frictionless plane. I did F=m dv/dt= m dv/dx*dx/dt= -2ma2x-5
Then I fould potential energy by integration. However I could not find the motion of the particle.
How do you specify the motion of a particle at a given time or at a given place? You give the velocity and acceleration. What are they at x=a?
Sorry for the incomplete question.
If the particle starts at the position x = a, find its motion as a function of time.
You know that v=dx/dt. You have the equation dx/dt=ax-2 This is a very simple separable differential equation. Can you solve?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
