Finding forced response in RL circuit with controlled current source
4 replies · 3K views · last reply
Quboid
vf= 4(u(t)-u(t-1.8))v
I have to find i(t), for the attached circuit. I already evaluated it for t<0. But i a having problems in the rage 0<t<1.8.
I am at the point where i have to find the forced response, so o let t tend to infinity
(t->infinity). And so the Inductor acts like a short circuit, the problem i have is find the current that passes where the inductor short circuits, I get confused by the controlled current sources.
I so far used kirchhoff voltage law to find three equations, but i am not sure i am correct, nor what to do with the dependent current source that finds itself in an equation.
Thanks for helping...
Quboid...
  • Circuit schematic with a voltage source VF, a 5 ohm resistor, a 0.5 H inductor on the top branch, a dependent voltage source 2vx, a dependent current source 2i1, and a 10 ohm resistor with voltage Vx across it.
is there any simple way of calculating i1 in the circuit, that would make things a lot easier.
Ok, i am thinking i1=i-(4v/5ohms). Note i got the 4 volts( which is supplied by the independent voltage source) from the scalar function vf, when evaluated in the range 0<t<1.8.
I've never seen some of the circuit elements in your drawing. Who's reinventing electronics and why?
I think if you want any help, you're going to need to decode that stuff.
Sorry about that. I didn't use a circuit schematic program to draw the circuit. I actually labelled them. I was hoping that would be sufficient. I solved the question yesterday one hour before the class. I will post the solution and a proper diagram shortly.
