Finding mass of a planet when density varies with radial distance
The discussion revolves around calculating the mass of a planet with a density that varies with radial distance, described by the equation ρ(r) = ρo(1 - αr/Ro). Participants are tasked with determining the total mass of the planet and the weight of a one-kilogram mass at its surface.
  • Participants discuss the need to integrate the density function over the radius to account for varying density. There are attempts to set up the integration and calculate the mass of spherical shells, but confusion arises regarding the correct application of the integration process.
Several participants have attempted integration to find the total mass, but discrepancies in results indicate a lack of consensus on the correct approach. Some have provided guidance on considering the geometry of the planet and the mass of differential shells, while others express uncertainty about their calculations.
Participants are working under the constraints of a homework assignment, which may limit the information available and the methods they can use. There is an ongoing exploration of assumptions related to the integration process and the interpretation of the density function.
Smartguy94
The density of a certain planet varies with radial distance as:
ρ (r)= ρo(1- αr/Ro)
where Ro= 3.98 x 106 m is the radius of the planet, ρo= 4980 kg/m3 is its central density, and α = 0.17. What is the total mass of this planet ?
Calculate the weight of a one kilogram mass located on the surface of this planet.
ρ = m/v
since ρ= m/v
then
m = ρv
v of a planet = 4/3∏ R^3
so i substitute the given info on the equations and got
m = ρo(1- αr/Ro) * 4/3∏ R^3
calculate all of those and I realize that i don't know what r is.
so I assume that r = Ro but I got the wrong answer
any help?
Since the density changes with radius (r), you will need to set up an integration over the radius r and sum the mass shells from the center (r = 0) to the surface (r = Ro).
i integrate the ρ as a function of r
3.98x10^6
∫ ρo(1- αr/Ro)dr
and got 3641700 as my answer
since ρv = m
and v = 4/3 ∏ Ro^3
m = 6.07x10^13
but its wrong, what did i do wrong?
3.98x10^6
∫ ρo(1- αr/Ro)dr
since ρv = m
and v = 4/3 ∏ Ro^3
m = 6.07x10^13
The ρ(r) function only gives you the density at a given radius. It does not address the geometry of the object. You need to determine the mass of each shell of matter of differential thickness dr, and sum them all up (integrate). In this case the shells will be spherical, and of thickness dr. So first find an expression for the mass of a spherical shell of thickness dr.
m = ρv
∫m = ∫ρv ?
which results to same exact answer as before?
Since the density only varies as the radius, and not as the latitude and/or longitude, the volume element is
dV=4πr2dr
After all, the total volume of a sphere of radius R0 can be obtained from \displaystyle V=\int_0^{R_0}4\pi r^2\,dr\,.
So the total mass of the planet is \displaystyle M=\int_0^{R_0}(ρ(r))4\pi r^2\,dr\,.
dV=4πr2dr
i did that integration and got 1.147x10^24 and its still wrong...
Can you show us how you did the integration? I got \approx 4.1 \times 10^{24}
  • · Replies 62 ·
