Finding minimum angle of friction.
To find the minimum angle of friction for a ladder leaning against a frictionless wall, the discussion emphasizes setting up the equilibrium equations correctly. The user attempts to establish a torque balance using forces acting on the ladder, specifically focusing on normal force and friction. A sign error in the torque calculation is noted, indicating that the second term should represent counter-clockwise torque. Participants suggest correcting this error and combining it with the friction equation and the conditions for vertical and horizontal force equilibrium. Properly addressing these elements will lead to deriving the formula for the minimum angle at which the ladder will not slip.
pooface
A uniform ladder of mass m and length L leans at an angle of theta against a frictionless wall. If the coefficient of static friction between the ladder and the ground is mu, determine a formula for the minimum angle at which the ladder will not slip.
I have added my own additional information in red.
various equations perhaps.
mu= Ffr/FN
Ffr is friction force.
FW is force by the wall
http://img171.imageshack.us/img171/1830/s8sv4.jpg
this is what I have done. I took my ref point at the top of the ladder.
(FN)(Lcostheta) + (Ffr)(Lsintheta) = (mass*g)(L/2 costheta)
I don't know if this approach is correct. I doubt it.
Can someone give me head start here?...I have been stuck on this problem for a while now. How do I set this up?
Thanks.
Nothing wrong with this approach. Except for a sign error: the second term is a counter-clockwise torque.
Fix that error and keep going. Combine this with the friction equation. And with the fact that vertical and horizontal forces must add to zero.
