greener1993
- 43
I need help on how to work out uncertianity is there a set equation for it?
i found this on the web
Step 1:
Add up all your values and divide by the number of values
Step 2:
Subtract each value from this average value and take the absolute value from this (positive numbers)
Step 3:
Add up all these absolute values and divide by the number of values
Step 4:
Take this value and divide by the square root of the number of values you have
This 4 step process gives you the uncertainty of the data you have collected
is this correct?
1) when measuring wire i got the resualts of
0.28mm
0.28mm
0.28mm
0.29mm
0.29mm
0.29mm
0.28mm
0.29mm
The actual width of the wire said on the roll was 0.28mm and theses were taken with a electronic vernier scale which measures to 2dp of a mm. (if this is of any use)
i also read that if the uncertainity is below what the equipment can measure it is neglecable. And i also need to know how to turn it into a percentage
thanks in advanced
Step 1:
Step 2:
Step 3:
Step 4:
is this correct?
0.28mm
0.28mm
0.28mm
0.29mm
0.29mm
0.29mm
0.28mm
0.29mm
thanks in advanced
