Finding Projection of Force onto line
To determine the magnitude of the projection of a force vector F = 700N along the u axis, the discussion emphasizes the need to identify the unit vector u and the components of the force vector. The participants clarify that the projection can be calculated using the dot product formula, where the projection of F onto u is given by |F·u|. They explore the relationship between the vectors and the angles involved, particularly in a 30-60-90 triangle context. Ultimately, the calculation leads to a projection result of approximately 287N, highlighting the importance of using unit vectors and maintaining precision in intermediate calculations.
Bluestribute
Determine the magnitude of the projection of force F = 700N along the u axis.
Cosθ = (A • B)/(||A|| * ||B||)
I'm guessing I have to use the above equation, but my problem is finding the B vector. A is easy enough (<-2, 4, 4> I believe), but what about that B? Or am I thinking of this in the wrong way?
You have a generic formula for ##\cos\theta##. What two vectors are A and B in your problem?
Well, I'd say A would be from the origin to A. I have no idea what B would be as there's only two lines, one point, and no other coordinates besides for the beam.
It looks to me like the "B" vector would be a vector from the origin along the direction u.
It looks like A is the point at the end of the hardware. But you are given a force vector ##\vec F##. That would be your A. And it asks for the projection along the ##u## axis. Isn't that a hint for B? And you are going to need the formula for the magnitude of the projection of one vector on another.
Well there's no coordinates anywhere along the u axis so I don't know how to find the vector for it . . . And are you talking about the formula F_{}parallel = Fcos\theta? How would I use that in this problem since it doesn't give the required answer . . .
There's an angle. That's all you need.
You're going to have to explain how I use it in the problem . . .
Do I use Fcosθ to find the magnitude of the B vector? If I'm using the equation:
F^{}p = (A • B)/(A*B) (vectors on top, magnitudes on bottom)
How does the Fcosθ equation help at all? It's not the answer they're looking for, I know that much . . .
My problem is, how the hell do I use a dot product with only one vector known? And what do I do with Fcos(theta)?
Your vector u is in the xy plane. You have an angle given. Can you figure out the components of a unit vector in the direction of u?
Alright, so my unit vector is <(1/2),(rt(3)/2,0>? My A vector is <-2,4,4>? Where do I use the 700N? Is it really:
<(1/2), (rt(3)/2), 0> • <-2, 4, 4> = 700cos(30)B?
Ok, you now have a unit vector in the direction of u. As I told you before, A is not the vector you want for the force. You are given ##\vec F## which is in the same direction as A but it isn't A because ##\vec F## is 700 units long. You need to to two things:
1. Figure out the vector ##\vec F## (its components).
2. Find the formula in your text that tells how to find the component of one vector on another.
You're assuming I have resources . . . which I don't except for this forum since Google returns nothing.
U = < 1/2, \sqrt{}3/2, 0 > (unit vector on the "u" line)
A = < 233.33, 466.67, 466.67 > (unit vector of the force multiplied by 700)
U • A = ||A||*||B||*cosθ, where ||A|| = 700 and θ = 30°
Is this right?
OK, let's talk about projections in general then. You need to know how to find the projection of an arbitrary vector ##\vec x## onto a 1-dimensional subspace U. Let ##\vec y## and ##\vec z## be the unique vectors such that ##\vec y## is in U, ##\vec z## is orthogonal (perpendicular) to every vector in U, and ##\vec x=\vec y+\vec z##.
We're looking for a formula for ##\vec y##. If ##\vec u## is a unit vector in U, there's a unique real number r such that ##\vec y=r\vec u##. So we can write ##\vec x=r\vec u+\vec z##. Now what do you get if you use this formula to compute ##\vec u\cdot\vec x##? The result is simply r. (You should verify that). So we have ##\vec y=r\vec u=(\vec u\cdot\vec x)\vec u##.
Ok, let me write out my interpretation and thinking:
\stackrel{\rightarrow}{z} is essentially a normal vector but for a line. The addition, I'm assuming, is basic trig (it's 10:00 here and my work is away).
I don't understand why we're searching for \stackrel{\rightarrow}{y}, unless it has to do with the specific problem here.
So the reason it equals simply r is because \stackrel{\rightarrow}{y} and \stackrel{\rightarrow}{z} are perpendicular? The ending is a bit fuzzy, but what I'm getting is that r = \stackrel{\rightarrow}{u} • \stackrel{\rightarrow}{x}
So if I was relating this to my problem, I would have to get the unit vector of u, which is simple enough because it's a 30-60-90 triangle, dot it with the unit(?) vector for the Force (aka point A), and multiply by the force? It's knowing when to use a unit vector and when to multiply by the force that I know for sure I'm struggling with.
That's the idea, but it's a bit easier to calculate it this way. If ##\hat u## is a unit vector in the direction of ##\vec u## then the magnitude of the component of ##\vec F## along ##\vec u## is just ##|\vec F\cdot \hat u|##. Remember, this is the scalar magnitude of the vector projection, and that's what the problem asked for.
Because ##\vec y## is by definition the projection of ##\vec x## onto U.
Right, two vectors are perpendicular if and only if their dot product is zero. So we get
$$\vec u\cdot\vec x=\vec u\cdot (r\vec u+\vec z)=r(\vec u\cdot\vec u)+\vec u\cdot\vec z=r|\vec u|^2+0=r.$$ And since ##\vec y=r\vec u##, this means that ##\vec y=(\vec u\cdot\vec x)\vec u##.
Do you understand this so far? Do you see how to use this result to find ##|\vec y|##?
By the way, the only reason I'm using the ##\vec x## notation is that I found \vec easier to type than something that makes the text bold, like \mathbf. (Not sure what is the best way to write vectors in bold). I see (when I'm quoting you) that you use a more complicated way to create that arrow. You can just type \vec x, or if you prefer, \mathbf x to get ##\mathbf x##.
You have found ##\vec F##. You have found ##\vec u##. (I think. I didn't check those results). And now you know the formula for the projection of an arbitrary vector onto an arbitrary 1-dimensional subspace, such as the straight line marked u in the picture.
Likes 1 person
Ok, so here's what I ended up doing.. I have two more problems for this section, but I want to know if I'm doing it right (so expect more topics . . . or hopefully not if I'm understanding).
I took ##\vec F## (the coordinates of point A multiplied by the magnitude of F) and dotted it with 30-60-90 unit triangle (which had no z components). Essentially ##\vec u## • ##\vec x##, though my x in this case was ##\vec F##. Then I multiplied by my unit vector and got 290, the answer.
And I'm going to start using that notation because I'm going to be here for a while. With all the money I get from my scholarship, I should be paying you guys. This forum saved all of us last year . . .
I hope that isn't what you mean. You have to multiply a unit vector in the direction of A by the magnitude of ##\vec F## to get ##\vec F##.
Yes yes, I meant unit vector. I've just been writing it so much I started writing sloppy shortcuts but yes, unit vector A.
The explanation of what you did got weird in the next paragraph too:
It sounds like you took ##\vec u\cdot\vec F## (a number) and multiplied it by ##\vec u## (a vector), and got the final answer ##(\vec u\cdot\vec F)\vec u## (a vector), and then you said that this is equal to 290 (a number).
I still think you did the right thing, which is to calculate ##|\vec u\cdot\vec F|##. I got a result close to 290, but not quite that. It's of course possible that I've made a mistake, but I have to ask if you're rounding off to the nearest multiple of 10 or something like that.
I most definitely rounded at the end (I got like 291.652319 . . . I don't know the decimal).
Actually, reading my work, I ended up finding the unit vector from the force. Then I multiplied the magnitude of the force through its unit vector. I took this new ##\vec F## and dotted it with the unit vector (along the path of projection).
That worked for the rest of the problems in the set too.
Hm, rounded off to the nearest integer, I got 287. I guess you also rounded off intermediate results. If you're going to do that, you should include a few extra decimals in the intermediate results.
\begin{align}
&\vec F=\frac{700}{\sqrt{36}}(-2,4,4)\\
&\vec u=\bigg(\frac{1}{2},\frac{\sqrt 3}{2},0\bigg)\\
&\|\vec F\cdot\vec u\| =\frac{700}{\sqrt{36}}\big((-2)\frac{1}{2}+4\frac{\sqrt{3}}{2}+4\times 0\big) =\frac{700}{\sqrt{36}}(-1+2\sqrt{3})\approx 287.
\end{align}
