Finding rank(range) and nullspace of a matrix
  • Thread starter Thread starter caliboy
    Matrix Nullspace
caliboy
Trying to figure out the rank and nullspace of the matrix of matrix A and B:
A=
1 0
5 4
1 4
B=
1 0 1
5 4 9
2 4 6
I used the Guass elimination on both
For A I said r3\rightarrowr3-r1, then r3→r3+4r1 then r2→r2-5r1 that lead to me getting
A=
1 0
0 4 Rank=2 and Null space=0
0 0
For B I said r3→r3-r2, then r3→r3+3r1 that lead me to:
B=
1 0 1
5 4 9 Rank=2 and Null space=1
0 0 0
Am I on the right track or do I have these completely wrong?
Are you trying to find the null space or the nullity, which is the dimension of the null space?
I am looking for the nullspace not the nullity. The "nullspace" that I have in the fist post is the nullity. I have been stuyding this and am using the formula Axp=c and am not really understanding how I got a nullspace of (0,0)
I found A=
1x1+0x2=0
0x1+4x2=0
0x1+0x2=0
and a nullspace of:
still looking at B
The null space is just the set of vectors that satisfy Ax=0. In your first example, the only solution is x=(0,0), so the null space is {(0,0)}, which is a vector space of dimension 0.
For your second problem, you found the nullity is 1, so the null space should turn out to be a vector space of dimension 1. That is, it should be the multiples of some vector. You want to figure out what that vector is by solving Bx=0.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
