Finding tension in a cable of a accelerating lift
The discussion revolves around calculating the tension in a cable supporting an 800 kg lift accelerating upwards at -0.1 m/s². The initial calculation yielded a tension of -7760 N, which raised confusion regarding the sign convention. Participants clarified that tension should always be positive, and the correct approach is to consider the forces acting on the lift, leading to a revised calculation of T = 800 x 9.7 = +7760 N. The conversation emphasized the importance of consistent sign conventions to avoid confusion in physics problems. Ultimately, the correct tension in the cable is +7760 N.
Sleve123
A lift has mass 800 kg. It is moving upwards and has an accerleration
of -0.1 ms-2. The lift is supported by a single cable.
What is the tension in the cable?
I get T = -7760 N (I'm taking up as negative), just checking what anybody else gets
F = ma
T + mg = -(-0.1)m
T = 800(0.1 - 9.8) = -7760 N
Welcome to PF!
Hi Sleve123! Welcome to PF! :smile:
Sleve123 said:
T + mg = -(-0.1)m
Assuming ths is one of Mr Otis's new-fangled lifts :rolleyes:, with the cable above the lift …
shouldn't T be opposite to mg? :wink:
(and negative tension would be compression)
I think what I've done is work out the force applied to the lift to produce that outcome.
In my equation:
T + mg = -(-0.1)m
The value of T could be positve or negative.
Doesn't the negative value just tell me that the force applied on the lift from the tension in the wire is in the up direction (because I took up as negative), not down.
No, tension can only be positive.
(plus, the question itself asks "What is the tension in the cable?", and you can't give a negative answer to that)
That's extremely confusing, and almost bound to lead to mistakes :redface:
In an exam, even if you get the correct answer, the examiner will probably think it was just luck.
Try it again, with T positive. :smile:
So:
mg - T = -(-0.1)m
T = m(g - 0.1)
T = 800 x 9.7 = +7760N
Sleve123 said:
So:
mg - T = -(-0.1)m
T = m(g - 0.1)
Yup! :biggrin:
(though, again, you seem determined to make things complicated …
the question gives an upward acceleration, so wouldn't it be safer to go with upward directions, avoid the double-negative, and write T - mg = -0.1m ?)
Likes WherE mE weeD
Thanks, as long as I'm right. I'll make it simpler for myself next time.
