Finding the change in the eigenvalue without knowing the change in the
  • Thread starter Thread starter JBrandonS
    Change Eigenvalue
JBrandonS
Hello,
I am currently teaching myself quantum mechanics using MIT's OCW and am suck on the following problem from the second problem set of the 2005 7.43 class.
Consider an operator O that depends on a parameter λ and consider the λ-dependent eigenvalue equation:
O(λ)| \psi(λ) > = o(λ) | \psi(λ) >
Show that one can compute \frac{do(λ)}{dλ} without knowing \frac{d|\psi(λ)>}{dλ}. Thus one can determine the change in the eigenvalue without knowing the change in the eigenstate.
Under what conditions would O(λ) commute with O(λ')
I really have no idea where to begin on this one.
JBrandonS said:
Hello,
The first question looks like the Hellmann-Feynman theorem. Multiply by ##<\psi(λ)|## on the left and take the derivative and I think you need O to be Hermitian. Really not sure about the second half.
Thank you, like most of these problems it became really easy once I got a push. Took about 30 seconds to show.
I also believe the only case where O(λ) would commute with O(λ') would be for degenerate eigenvalues, but maybe someone else can chime in and let me know if that is right or wrong.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
