Finding the currents in this circuit (2 voltage sources and 3 resistors)
The discussion revolves around analyzing a circuit with two voltage sources and three resistors, focusing on finding the currents through the components using Kirchhoff's laws. Participants are attempting to set up equations based on their interpretations of the circuit diagram.
  • Mixed
  • Participants are setting up systems of equations based on Kirchhoff's rules, with some attempting to express currents in terms of each other. There are questions about the correctness of the loop equations and the assumptions made regarding current directions.
The discussion includes various attempts to derive equations, with some participants questioning the validity of their setups. There is an ongoing exploration of the implications of current directions and voltage contributions, with no clear consensus on the correctness of the approaches yet.
Some participants express confusion regarding the circuit diagram and the assumptions about current flow, which may affect their equations. There are indications of differing interpretations of the loop directions and voltage polarities in the circuit.
Nat1234123
Which current ratings do I1, I2 and I3 have if the resistances hold R1 = 0.1 ohm, R2 = 0.02 Ohm and R3 = 0.2 Ohm?
U = IR
1/R = 1/R_1 + 1/R_2 + ....
I1 = I2 + I3
In my attempt, I tried
1) I1 = I2 + I3
Then set up these two equations based on Kirchhoff's second rule:
2) U1 = R1 (I2) + R3 (I3) and
3) U1 + U2 = R1 (I1) + R2 (I3).
From what we have
10 = 0.1* I_2 + 0.2 * I_3
22 = 0.1* I_2 + 0.02*I_3
I_3 = 50 - 0.5 I_2
That means
I_2 = 233.3 A
I_3 = -66.7A
I1 = 166.6A
My answer is completely off.
1) I1 = I2 + I3
That does not comport with your drawing.
If I fix that part, will the rest be right then?
No. Start there and rework the problem.
Substitute I3=z, I2=y and I1=x.
System of equations:
z = y + x
12−0.2z−0.02x=0
−10+0.2z+0.1y=0
From second and third equation solve:
x=−10z+600
y=100−2z
Add these to the first:
z=(100−2z)+(−10z+600)
z=700/13
z~53,85
Thus I3~53,85 , I2~-7,7 and I1~61,5
Hope this helps!
z = y + x
12−0.2z−0.02x=0
−10+0.2z+0.1y=0
Hope this helps!
Your second loop equation (the last equation I quoted above) is incorrect. Which direction around the loop did you use?
How come? Clockwise, i.e. U2 is positive direction and U1 is negative direction.
Previously I quoted the following from your Post #5.
z = y + x
12−0.2z−0.02x=0
−10+0.2z+0.1y=0
The loop equation I referred to is:
##\displaystyle \quad −10+0.2z+0.1y=0 \ ##.
You are correct in that going clockwise around the outer loop the voltage contribution from ##U_1## is ##-\,10## volts. However, the clockwise direction around this loop is also consistent with the given choice of current direction for both ##I_2## and ##I_3##, so both give voltage drops (negative) across their respective resistors. In other words that loop equation should be:
##\displaystyle \quad -U_1-I_3 R_3 - I_2 R_1 = 0## .Your other equations are correct.
So basically higher voltage U2 is "charging" lower voltage U1 since given the orientation of U1 the current is reversed! Agreed!
I wouldn't put it that way, because you will find out that ##I_2## (which you relabeled as y) is negative, so the current flows through ##U_1## from the negative terminal to the positive terminal, opposite the direction chosen for ##I_2## in your drawing.
But after calculus one will find out I1 to be the largest and not I3, thus U1 has to be a load and not a source?
