Finding the distance a plant falls
  • Thread starter Thread starter mathforkicks
    Plant
To find the distance the flowerpot falls from the windowsill to the top of the window, the time taken to pass the window (0.420 seconds) and the height of the window (1.90 meters) are used in the calculations. Ignoring air resistance, the distance fallen can be derived from the equations of motion. The initial solution provided indicates that the distance from the windowsill to the top of the window is approximately 0.31 meters. This calculation confirms the relationship between time, height, and free fall in physics.
mathforkicks
A freefall problem
A flowerpot falls off a windowsill and falls past the window below. You may ignore air resistance. It takes the pot .420 s to pass this window, which is 1.90 m high. How far is the top of the window below the windowsill from which the flowerpot fell?
Show us first your initial solution... :smile:
.31 m
mathforkicks said:
.31 m
That looks good.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 16 ·
37K
19K
