Finding the force needed for equilibrium.
  • Thread starter Thread starter Crusaderking1
    Equilibrium Force
To find the forces F2 and F3 needed for equilibrium against a 2.45 N force, the angles of F2 and F3 are given as 35 degrees and 50 degrees, respectively. The equations F2 cos 35 degrees - F3 cos 50 degrees = 0 and F2 sin 35 degrees - F2 sin 45 degrees - mg = 0 are used to set up the problem. The discussion emphasizes the need for clarity on the angles' reference points and the components of the forces involved. The conclusion reached is that both F2 and F3 were calculated to be 3.87 N, although there is uncertainty about their equality and the overall setup of forces in the problem.
Crusaderking1
5. Find the magnitudes of the forces F2 and F3 that you would need to balance a 2.45 N force at 0.0 degrees If the angle of F2 is 35.0 degrees and F3 is 50 degrees.
F2 cos 35 degrees - F3 cos 50 degrees =0
F2 sin 35 degrees -F2 sin 45 degrees -mg= 0
-.25 =m
g= 9.80 m/s2
F2 sin 35 degrees -F2 sin 45 degrees = 2.5
Is this set up right? Thanks.
Is there a better way to calculate the forces to find equilibrium?
-.25 =m
g= 9.80 m/s2
I would need to know what your angles are measured with respect to??
angle between f2 and f3 are 85 degrees. f2 is 35 degrees, and f3 is 50 degrees. 3 forces are acting on each other. f1 is just a straight line between them.
Crusaderking1 said:
angle between f2 and f3 are 85 degrees. f2 is 35 degrees, and f3 is 50 degrees. 3 forces are acting on each other. f1 is just a straight line.
OK the angle between f2 and f3 you have stated.
f2 is 35 degrees. 35 degrees to what?
f3 is 50 degrees. 50 degrees to what?
Try giving True bearings. 0 degrees is North, 90 degrees is East, 180 degrees is South, 270 degrees is West.
35 degrees north of west
50 degrees south of west
OK then
I am assuming then that f1 it due East.
The vertical components of f2 and f3 must be equal in magnitude - they are already opposite in direction
The horizontal components of f2 and f3 must add to 2.45 N to balance f1.
PeterO said:
OK then
Would mg/sq. root 2 work?
I don't thing so. You need sine and cosine functions to work out the components
ok thanks!
I received 3.87 N for both f2 and f3 magnitude.
I can't see that they would be equal.
Can you confirm that 2.45 N East is the only other force involved.
It this whole thing on a horizontal plane or is there a weight hanging somewhere/some how?
