Finding the height of a building
  • Thread starter Thread starter moy13
    Building Height
Spiderman falls from a building, covering a distance of h, with the last 1.2 seconds accounting for h/4 of that distance. The discussion involves using kinematic equations to derive the height h based on constant acceleration due to gravity, -g. Participants attempt to calculate average velocity and time intervals but encounter issues with algebra and sign errors. The correct approach involves setting up equations for displacement and velocity, ultimately leading to a quadratic equation for h. Careful attention to signs and algebraic manipulation is emphasized to arrive at the correct solution.
moy13
Spiderman steps from the top of a tall building. He falls freely from rest to the ground a distance of h. He falls a distance of h/4 in the last interval of time of 1.2 s of his fall.
What is the height h of the building?
The acceleration is constant -g.
y(t) = y(0) + v(0)t - 1/2gt^2
v = v(0) - gt
v^2 = v(0)^2 - 2g(y-y(0))
I found the average velocity of the final interval of time to be (h/4)m / 1.2s = (h/4.8)m/s.
I know the average velocity occurs at half the displacement; so, I used this velocity as the initial velocity for another displacement of h/8 (or half the distance of the final interval).
Then I tried using g = -9.8m/s^2, v(0) = -(h/4.8)m/s, y(0) = (h/8)m, and y = 0 to find the time spiderman takes to travel that distance, but I cannot do that without figuring out h, my original target.
Please help.
Write out equations for what you know.
h = 1/2*g*T2
T is your total time.
0 = 1/4 h - V1/4 *(1.3) - 1/2*g*(1.2)2
V1/4 is the velocity at 1/4 h.
Since he started from rest:
V1/4 = g*(T - 1.2)
Solve for T and that will give you h won't it?
I tried solving for T but I still got a wrong answer for h
It should be
0 = 1/4 h - V1/4 *(1.2) - 1/2*g*(1.2)2
Saw that 1.3 too, but I changed it to 1.2 and it's still wrong. Maybe I'm not understanding the concept. How do I solve for T?
Is it T = sqrt( 2h/g )?
and v(1/4) = g * ( sqrt( 2h/g - 1.2 )?
then solve for h. It's what I did, but I got 254m which is wrong.
Put h = 1/2*g*T^2 and V1/4 = g*( T-1.2) in the equation. You get
1/4*1/2*g*T^2 - g*(T-1.2)(1.2) - 1/2*g*(1.2)^2 = 0
Cancell g through out and solve for T.
Oops. Yes the 1.3 was a definite typo. Thanks for pointing that out rl.bhat.
Solving the quadratic gives me a different number than 254.
I can only suggest taking care with the signs and the algebra.
