Finding the intensity of radiation ?
To find the intensity of radiation from a 150 W Xenon lamp at a distance, the theoretical intensity can be calculated using the formula 150/(4πr^2) W/m^2, assuming no absorption by the air. A photodiode can be used to measure the intensity, and a photometer can provide output for visible light irradiance. This calculation gives a maximum value for intensity, and additional data about the bulb may refine the results. Understanding these methods will help in accurately determining the light intensity on a surface. Accurate measurement techniques are essential for precise applications.
mkbh_10
I have a 150 W Xenon lamp with me and I need to know what is the intensity(W/m^2) of light being radiated on a surface at x distance away . How do I do it ?
Can I use a photodiode, if yes then how ?
You could look for a photometer which can output irradiance for visible light.
I can tell you how to CALCULATE the intensity if you assume that 150W is all light.
The 150W passes through the surface of a sphere of radius r as it spreads out (assuming no absorbtion by the air) so the theoretical intensity = 150/(4πr^2) W/m^2
I am certain that this is not a good enough answer for you but it will give you a maximum value and if you have more data about the bulb then I hope it is of some use.
good luck
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
