Finding the Limit of a Function Using Delta-Epsilon Definition
  • Thread starter Thread starter step1536
    Definition Limit
The discussion revolves around finding the limit of a function using the delta-epsilon definition, specifically focusing on the function f(x) = x^2 and its behavior near x = 1. Participants are examining the conditions under which |f(x) - 1| < 1/2 holds true when |x - 1| < delta.
  • Participants are attempting to clarify the problem statement and the conditions necessary for determining delta. There are questions about the completeness of the original problem setup and the need for clearer punctuation and definitions.
The discussion is ongoing, with some participants providing interpretations of the problem and suggesting graphical methods to visualize the relationship between x and f(x). There is a recognition of the need for more precise information to facilitate understanding.
Some posts indicate that the original problem lacks clarity, and there are requests for additional details to better assess the situation. Participants are also encouraged to consider the implications of rounding and the specific constraints of the delta-epsilon definition.
step1536
Given points (0.8,0.5), (1.2,1.5)
f(x) =x^2 |x^2-1| < 1/2 whenever |x-1| <delta correct to four decimals round down if necessary
You have shown an attempt at a solution, but haven't shown the problem itself. This makes it more difficult for us to determine what you're trying to do. Please add this information. Punctuation would be nice, too.
Use the given graph of(x) =x^2 |x^2-1| < 1/2 whenever |x-1| <delta .The Given points on the graph are(0.8,0.5), (1.2,1.5). Please give your answer to the value of delta, where deltaor any smaller positive number will satisfy all conditions. correct to four decimals, round down if necessary.
That's not much of an improvement over what you had in the first post. Here is what I think the given problem is.
f(x) = x2
Find a value of delta so that when |x - 1| < delta, |x2 - 1| < 1/2.​
In other words, how close to 1 must x be so that x2 will be within 1/2 of 1? Draw a graph of the function. On your graph, draw a horizontal line through the point (1, 1). Draw two more horizontal lines, one 1/2 unit above the first line and the other, 1/2 unit below the first line. At the points where these two lines intersect the graph of y = x2 in the first quadrant, draw vertical lines down to the x-axis. The two intervals to the left and right of (1, 0) can help you find what delta needs to be.
  • · Replies 31 ·
