Finding the maximum value of a gravitional force field
The discussion centers on finding the maximum gravitational field value created by two identical particles positioned symmetrically on the x-axis. The gravitational field formula is given, and the focus is on determining the maximum value along the y-axis. Participants clarify that while the textbook suggests considering only positive y-values, the symmetry of the problem implies that maxima exist symmetrically above and below the x-axis. The need to take the derivative of the gravitational field expression is debated, with the conclusion that since x_0 is constant, an ordinary derivative with respect to y suffices. Ultimately, the reasoning concludes that the gravitational field has a global maximum due to its behavior at the boundaries and its continuous nature.
Calpalned
Two identical particles, each of mass m are located on the x-axis at ## x=+x_0 ## and ## x = -x_0##. At what point (or points) on the y-axis is the magnitude of ##\vec g ## a maximum value and what is its value there?
Formula for gravitational field ##-2Gm \frac {y}{(x_0^2 + y^2)^{3/2}} ##
The textbook's first step is to keep y a positive quantity. " If we keep y as a positive quantity, then the magnitude of the field is ##2Gm \frac {y}{(x_0^2 + y^2)^{3/2}} ##
How is this a legal move? We want to find the maximum value, so shouldn't we be considering the entire y-axis and not just the part above the x-axis? How can we be so sure that the maximum is actually above the x-axis?
By symmetry it is obvious that the pattern of gravitational force below the x-axis will be a mirror image of the pattern above. If you find a maximum for positive y, there will be an identical maximum for negative y. There is no point looking for both maxima when finding the one will reveal the other.
Likes Calpalned
The textbook also gives me a hint "Take the derivative of ##\frac {d \vec g }{dy} ## However, there are more than one variable in the formula for gravitational field. Therefore, why don't we take a partial derivative?
Never mind. I just realized that ##x_0## is a constant. Therefore, a partial derivative is not needed.
Likes jbriggs444
There is only one variable. The other values are constants. You could call them variables and take a partial derivative with respect to y. Or you can call them constants and take an ordinary derivative with respect to y. Both amount to the same thing.
Likes oceanzaza and Calpalned
We find locations of the maximum magnitude by setting the first derivative equal to 0. Since the expression is never negative, any extrema will be maxima.
Expression: ##g = 2Gm \frac {y}{(x_0^2 + y^2)^{3/2}} ##.
What makes this statement true? For example, the equation ## y = x^2 + 1 ## is never negative, but its extrema is a minimum.
You are right. As written, that reasoning is incorrect. More correctly, one could reason that since the expression is zero at zero, zero at infinity, bounded, strictly positive and continuously differentiable between that it must have at least one extremum which is a global maximum and at which the first derivative is zero somewhere in that range.
thank you
