Finding the Moment of Inertia of a System
The discussion focuses on calculating the moment of inertia of a system of particles connected by massless rods and rotating about the x-axis. The initial calculation incorrectly used negative distances, leading to confusion. The correct formula for the moment of inertia involves summing the products of mass and the square of the distance from the axis, resulting in a total of 92 kg-m². It is emphasized that distances should be treated as positive values when calculating moment of inertia. The final conclusion confirms the correct moment of inertia for the system.
Jacob87411
Rigid rods of negligible mass lying along the y-axis connect three particles (Fig. P10.20). The system rotates about the x-axis with an angular speed of 1.20 rad/s.
(a) Find the moment of inertia about the x axis.
So isn't the moment of inertia given by the sum of mr so..
(4kg)(3m)+(2kg)(-2m)+(3kg)(-4m) = -4?
That should be the sum of m r^2.
so (4)(3^2)+(2)(-2^2)+(3)(-4^2) = (4)(9)+(2)(4)+(3)(16)=36+8+48=92?
Likes claire123456789
Yes, in units of kg-m^2.
(Realize that r is the distance from the axis, so it should be positive.)
