Finding the number of ways to arrange identical balls in a circle
  • Thread starter Thread starter songoku
songoku
Find the number of ways to arrange 2 red balls, 2 blue balls and 1 yellow ball in a circle
cyclic permutation = (n - 1)!
permutation with identical objects = ##\frac{n!}{r_{1}! r_{2}! ...}##
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense.
Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities?
Thanks
I assume that two arrangements are considered equal if they are equal after rotation?
If so, you could start by fixing the position of the yellow ball.
Why 4 ?
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
