Finding the Polar Equation of a Circular Orbit in a Central Force Field
  • Thread starter Thread starter mark9696
    Polar Sketch
The discussion revolves around finding the polar equation of a particle's circular orbit in a central force field, with the force's origin located on the circle. Participants express confusion regarding the setup of the problem and the necessary steps to derive the equation.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss starting points for the problem, including references to specific equations and the need for clarification on steps involved. There are mentions of the inverse radius and potential forms of the equation, with some uncertainty about the correctness of the proposed solutions.
The discussion is ongoing, with participants seeking clarification on the derivation process and expressing varying levels of understanding. Some guidance has been offered regarding specific equations, but there is no consensus on the approach or final outcome yet.
There are indications of confusion regarding the notation and the derivation process, as well as references to external resources like a textbook. Participants also mention issues with typing and clarity in their posts.
mark9696
A particle moves on a circular orbit in a central force field. The origin of the force lies on the circle.
Find the polar equation of the orbit.
I am confused as to how to set up this question.
Start with the equation for the invers radius of the orbit with respect to angle
[tex]{d^2u}\over {d/ \theta^2} + u =[/tex]
Can't work it right now, back later... anyway it is r^-5.
I need a few more steps to be explained. I am sure that if you could please explain them to me that I will get it.
Also, I ahve never sen that queation before. IS it derived somewhere on the net?
Are you saying that the polar equation is r^(-5)? I need some help here desparately.
My typing is bad, and it was late.
Start with Goldstein 3-34a,
[tex]\frac{d^2 u}{d\theta^2} + u = -\frac{m}{l^2u^2}f(1/u)[/tex]
set [tex]1/u = 2acos\theta[/tex] and crank away. The answer should pop out when you eliminate the [tex]\theta[/tex].
For some reason, the \frac is not working...
