Finding the radius of a brass ball using tension?
To find the radius of a brass ball using the tension in a wire, start by recognizing that the tension (120N) equals the weight of the ball (T = mg). Calculate the mass of the ball by dividing the tension by the force of gravity. Once the mass is determined, use the mass and the known density of brass (80470 kg/m^3) to find the volume of the ball. Finally, apply the formula for the volume of a sphere (V = (4/3)πR^3) to solve for the radius. This approach effectively connects tension, mass, and volume to determine the radius of the brass ball.
rought
One end of a wire is attached to a ceiling and a solid brass ball is tied to the lower end. The tension in the wire is 120N what is the radius of the brass ball.
Brass Mass Density (kg/m^3) = 80470
I have no clue how to solve this one, can anyone help?
Start by drawing a free body diagram. You need to figure out the mass of the ball. How do you think you might do that?
Could you find the mass of the ball by taking the tension and dividing it by the force of gravity? Would tension equal the weight force (Mass x Gravity) ?
That's correct. Two forces act on the ball: The upward tension of the wire and the downward pull of gravity. They must balance, thus: T = mg.
Ok I got that, but how do you find the radius of the ball from the volume that I calculated from the mass?
What's the formula for the volume of a sphere?
V = (4/3)πR^3 right?
That's right.
hage567 said:
That's right.
Alrite I get what to do now, thanks a ton =]
You're welcome. :smile:
