Finding the resulant from the product
  • Thread starter Thread starter leolaw
    Product
To determine the empirical and molecular formula of limonin, start by converting the combustion products' masses of CO2 and H2O into moles. The total mass of products exceeding the original sample weight is due to the addition of atmospheric oxygen during combustion, which is not accounted for in the initial mass. Calculate the molar ratios of carbon, hydrogen, and oxygen from the moles of CO2 and H2O produced. Divide these values by the smallest mole quantity to obtain integer ratios, which will lead to the empirical formula. Finally, use the molar mass of limonin to derive the molecular formula from the empirical formula.
leolaw
I am new to Chem, and I don't quite understand how to solve this problem:
Component of citrus fruits is the bitter compound limonin, which contains only carbon, hydrogen, and oxygen. When a 1.000-gram sample of limonin is subjected to complete combustion, 2.432 grams of CO_2 and 0.574 grams of H_2O are producted. In addition, the molar mass of limonin is approximately 475 g/mol. Detrmine the emprirical formula and molecular fomrula of limonin.
I don't get how can you have a total of about 3gram for the product, whereas the resulatant is only 1gram? I thought the mass has to be equal throughout the problem
Chemistry news on Phys.org
atmospheric oxygen.
that is the whole point of the problem. you need to find the molar ratios to determine the formula for the limonin, and you need the masses to do this. once your molar ratios are balanced then the masses will work out.
so convert all of your masses into moles. divide them all by the lowest one to get integer values: these should be your molar ratios.
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
10K
11K
