Finding The Solution of A Differential Equation
Bashyboy
y' + 3y = t + exp(2t)
My solution is y = t/3 + exp(-2t) -1/9 + c. The solution in the back of the book is y = cexp(-3t) + (t/3) - (1/9) + exp(-2t). How come the two solutions differ so vastly? I followed the procedure outlined in the textbook precisely.
The solution I'm getting is :
##y(t) = \frac{c}{e^{3 t}} + \frac{t}{3} + \frac{e^{2 t}}{5} - \frac{1}{9}##
You should check your work over again I think. You may have made a slight error.
I got the exact same answer. I attached my work as a file. According to my textbook, the solution to this sort of differential equation is:
y = \frac{1}{\mu (t)} \int \mu (t) g(t) dt + c, where \mu (t) = e^{\int p(t)dt}
Yes your book is 100% correct ( Barring I'd leave constants all the way until the end ), but don't neglect the ##e^{3t}## in the denominator. It will vary the value of ##c## if you're ever given an initial value problem.
Oh, I see. So exp(-3t) would multiply the c, after I did the integration.
It will divide it actually. After evaluating the integrals I got this :
##e^{3t}y(t) = e^{3t} ( \frac{e^{2t}}{5} + \frac{t}{3} - \frac{1}{9} ) + c##
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
