Finding the value of an integral given a graph
The discussion centers on determining the value of the integral I=∫ from 0 to 8 |f(x)|dx using a graph of an antiderivative, F, of a function f. Participants initially struggle with calculating the integral, with one user employing a Riemann Sum technique but obtaining incorrect results. Clarification is provided that the graph represents the antiderivative, and the correct method involves evaluating F(b) - F(a) for the given limits. After some back and forth regarding the signs of f(x), the correct value of the integral is confirmed to be 11. The conversation concludes with a resolution and acknowledgment of the correct answer.
turbokaz
http://tinypic.com/view.php?pic=1xa2f&s=5 (this shows the graph that is related to the problem)
is the graph of an anti-derivative, F, of a
function f, use this graph to determine the value of I=∫ from 0 to 8 |f(x)|dx.
value of the definite integral
The answer choices are 11, 12, 13, 14, or 15. I have no idea how to get these answers. I looked at the graph and used Reimann Sum technique of counting up the squares, but I get numbers in the 20's. For absolute value functions, I know you switch any negative values to positive, but this whole function looks positive to me? Thoughts?
Hi turbokaz,
The plot is the antiderivative already, no need to integrate it further.
How do you calculate the definite integral between two points from the antiderivative?
What do you think about the sign of f(x)? In what domain is it positive and where is it negative?
ehild
F(b)-F(a)?
F(b) is 1, F(a) is 2. 1--2=3?
Bump...I'm still not getting anywhere
Nevermind. I understand the problem now. The answer is 11.
Congratulation!:smile:
ehild
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
