Finding this limit involving sin and cos
  • Thread starter Thread starter lo2
    Cos Limit Sin
lo2
I have this function:
f(x) = \frac{1}{x}-\frac{\cos{(x)}}{\sin{(x)}}
For all x \in R where x \neq n \pi, n \in Z
Ok I have to find the following limit:
lim_{x\rightarrow0+}(f(x))
Limits in general and perhaps the always great Hospital's rule.
I have tried to put on the same fraction line:
f(x) = \frac{\sin{(x)}-x\cos{(x)}}{x\sin{(x)}}
And then using the Hospital rule, but it does not really seem to bring me any further...
The first derivative of it is:
f(x) = \frac{x^2-1+(\cos{(x)})^2}{x^2(\sin{(x)})^2}
And then I could use the Hospital rule again but it just seems as though it will make it worse, the sinus will always be in the denominator.
First of all, you're not applying L'Hopital's Rule correctly. You're supposed to differentiate the numerator and denominator *separately*. Instead you differentiated the whole expression using the quotient rule. (BTW, even that expression you got can be further simplified. Use \sin^2 x + \cos^2 x = 1 on the numerator. Irrelevant to the question, but something you should take note of).
After you apply LHR correctly, take the reciprocal of the expression and see what it reduces to.
Alternatively, you can just apply the Taylor series throughout and get the answer quickly without using LHR.
Ah yeah ok, I can see that I have used LHR wrongly...
I think I have got the right answer applying the rule correctly! So thanks a lot :)
You're welcome. :smile:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
