Finding volume using triple integral
To find the volume of the solid defined by the equations x^2+y^2 > 1, x^2+z^2 = 1, and x^2+y^2 = 1, a triple integral approach is necessary, using the integrand of 1. The integration should be set up in cylindrical coordinates, specifically using dz, r, and dθ. The suggested limits for z are from 0 to sqrt(1 - cos^2(θ)) and from 0 to sqrt(1 - sin^2(θ)). The volume calculation focuses on the first quadrant, with the final result being multiplied by 8 to account for symmetry. Reevaluating the coordinate system may provide a clearer path to the solution.
woogirl14
I need to find the volume of a solid formed by the following equations:
x^2+y^2 > 1
x^2+z^2 = 1
x^2 + y^2 =1
I know that it is a triple integral and the integrand is 1.
I also know that I need to use dzrdrd\theta.
I believe that you need two integrals, one with z going from 0 to sqrt (1-costheta^2) and the other with z going from 0 to sqrt (1-sintheta^2). I only want to find the volume in the first quadrant then I will multiply by 8.
Have you been told you need to use dz rd rd\theta ?
If so then rethink you co-ordinate system when integrating, and look at your functions and see if you can convert them into any other coordinate system you know of
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
  • · Replies 21 ·
