Proving Continuity in Stronger and Weaker Topologies
  • Thread starter Ted123
In summary, we prove that if \tau_2 \subseteq \tau_1 then (a) if A \subseteq X is closed in (X,\tau_2) then A is closed in (X,\tau_1) and (b) if (Y,\tau_Y) is another topological space and f is a continuous map from (Y,\tau_Y) to (X,\tau_1) then f is continuous from (Y,\tau_Y) to (X,\tau_2). This is shown directly from the definitions, using the fact that \tau_2 \subseteq \tau_1.
Ted123
446
Suppose [itex]\tau_1[/itex] and [itex]\tau_2[/itex] are 2 topologies on a set [itex]X[/itex] and that [itex]\tau_2 \subseteq \tau_1[/itex]. We say that [itex]\tau_1[/itex] is stronger/finer than [itex]\tau_2[/itex] and that [itex]\tau_2[/itex] is weaker/coarser than [itex]\tau_1[/itex].
Show, directly from the definitions, that if:
(a) [itex]A \subseteq X[/itex] is closed in [itex](X,\tau_2)[/itex] then [itex]A[/itex] is closed in [itex](X,\tau_1)[/itex] ;
(b) [itex](Y,\tau_Y)[/itex] is another topological space and [itex]f[/itex] is a continuous map from [itex](Y,\tau_Y)[/itex] to [itex](X,\tau_1)[/itex] then [itex]f[/itex] is continuous from [itex](Y,\tau_Y)[/itex] to [itex](X,\tau_2)[/itex].
For (a), if [itex]A \subseteq X[/itex] is closed in [itex](X,\tau_2)[/itex] then, by definition, [itex]\partial A \subseteq A[/itex], but this is precisely the definition of [itex]A[/itex] being closed in [itex](X,\tau_1)[/itex] (the definition is dependent on the set, not the topology).
Is this OK - is there a better way to show it?
For (b), [itex]f:(Y,\tau_Y) \to (X,\tau_1)[/itex] is continuous if for every open set [itex]A\subseteq X,\; f^*(A)[/itex] is open in [itex]Y[/itex]. Again, isn't this just the definition of [itex]f:(Y,\tau_Y) \to (X,\tau_2)[/itex] being continuous?
This last comment isn't true, at least not the way I understand it. What is your definition of the boundary of A? It must depend on the topology of the space in some way. Where have you used the fact that [itex] \tau_2 \subseteq \tau_1 [/itex]?
The definition of closed I learned for a closed set is F is closed iff [itex] X \setminus F [/itex] is open. You could try starting there.
Again, where have you used the fact that [itex] \tau_2 \subseteq \tau_1 [/itex]? Maybe you're just omitting these because they seem clear, but I think it's important to mention where you use each piece of information.
[itex]\tau_2 \subseteq \tau_1[/itex] means every [itex]\tau_2[/itex]-open set is [itex]\tau_1[/itex]-open so for (a):
[itex]A[/itex] is closed in [itex](X,\tau_2) \implies A^c[/itex] is [itex]\tau_2[/itex]-open in [itex]X[/itex]
[itex]\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\, \implies A^c[/itex] is [itex]\tau_1[/itex]-open in [itex]X[/itex] (since [itex]\tau_2 \subseteq \tau_1[/itex])
[itex]\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\, \implies A[/itex] is closed in [itex](X,\tau_1)[/itex]
Does that look better?
However is every [itex]\tau_1[/itex]-open set [itex]\tau_2[/itex]-open? As for (b):
[itex]f:(Y,\tau_Y) \to (X,\tau_1)[/itex] is continuous [itex]\implies[/itex] for every [itex]\tau_1[/itex]-open set [itex]A \subseteq X,\; f^*(A)[/itex] is [itex]\tau_Y[/itex]-open in [itex]Y[/itex]
Does this imply the following?
[itex]\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\, \implies[/itex] for every [itex]\tau_2[/itex]-open set [itex]A \subseteq X,\; f^*(A)[/itex] is [itex]\tau_Y[/itex]-open in [itex]Y[/itex] (since [itex]\tau_2 \subseteq \tau_1[/itex]??)
[itex]\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\, \implies f:(Y,\tau_Y) \to (X,\tau_2)[/itex] is continuous
Looks good.
This would only be true if [itex] \tau_1 \subseteq \tau_2 [/itex], in which case the 2 topologies are equal.
As for (b):
This is fine, but you seem unsure, so maybe it would be better to start with an arbitrary open set O in [itex] (X, \tau_2) [/itex] and prove that [itex] f^{-1}(O) [/itex] is open in Y.
spamiam said:
Looks good.
The thing I was unsure about was every [itex]\tau_1[/itex]-open set... implying every [itex]\tau_2[/itex]-open set...
(as you say, wouldn't this only be true if [itex] \tau_1 \subseteq \tau_2 [/itex], in which case the 2 topologies are equal?)
You've got it backwards. You don't need every set in [itex] \tau_1[/itex] to be in [itex] \tau_2 [/itex] to prove the statement in part b). As I said before, try starting with an arbitrary open set O in [itex] (X, \tau_2) [/itex] and prove that [itex] f^{-1}(O) [/itex] is open in Y. Writing it out is the best way to make this clear.
1. What is a finer topology?
A finer topology is a topology on a set that contains more open sets than another topology on the same set. This means that the finer topology is more detailed and allows for more distinctions between points in the set.
2. How is a finer topology related to a coarser topology?
A coarser topology is a topology on a set that contains fewer open sets than another topology on the same set. This means that the coarser topology is less detailed and allows for fewer distinctions between points in the set. A finer topology is related to a coarser topology in that it contains all the same open sets as the coarser topology, plus additional ones.
3. Can a topology be both finer and coarser?
No, a topology cannot be both finer and coarser at the same time. This is because a finer topology contains more open sets, while a coarser topology contains fewer open sets. They cannot both be true simultaneously.
4. How are fineness and openness related in a topology?
In general, the finer a topology is, the more open sets it contains. This is because finer topologies allow for more distinctions between points in a set, which means more open sets are needed to cover the set. However, there are exceptions to this rule and it is not always the case.
5. How do finer and coarser topologies affect continuity?
A finer topology can make a function appear to be more continuous, as it allows for more distinctions between points in the domain. On the other hand, a coarser topology can make a function appear to be less continuous, as it allows for fewer distinctions between points. However, the actual continuity of a function is not affected by the topology chosen, as long as the topology is compatible with the function.
