How to Expand Finite Series in a Shorter Form?
JulmaJuha
Hello :blushing:
How to do expand this: (\sum_{j=1}^{n}(X(t_j)-X(t_{j-1}))^2 - t)^2 where X(t_j)-X(t_{j-1}) = \Delta X_j
to this: (\sum_{j=1}^{n}(\Delta X_j)^4 + 2*\sum_{i=1}^{n}\sum_{j<i}^{ }(\Delta X_i)^2(\Delta X_j)^2 -2*t*\sum_{j=1}^{n}(\Delta X_j)^2+t^2I get near the North Pole... but it seems that I've forgotten some fundamental rules of finite series to do the last part of the manipulation :smile:.I assume that the blue part has to be expaned further. This is what I've done:
\sum_{j=1}^{n}(\Delta X_i)^2 = a,t=b
E[(a-b)^2]=E[a^2-2ab+b^2]=E[\color{blue} {(\sum_{j=1}^{n}(\Delta X)^2)^2} \color{black} -2*t*\sum_{j=1}^{n}(\Delta X)^2+t^2]
Any help would be greatly appreciated.
I may be misunderstanding something, but I think the second term (with the double sum in i and j) should be multiplied by 2. Either that or the sum in j should be over j \neq i rather than j<i.
Anyway, you are correct to say that the blue term needs to be expanded further. Just try writing out one explicit example, say for n=2. Often, the compact summation notation obscures otherwise obvious patterns.
Also, you can use ( \sum_j f_j )^2 = ( \sum_j f_j ) ( \sum_i f_i ).
krome you're correct, its supposed to be multiplied by 2
No, it should not be multiplied by 2. If ##a_i = (\Delta X_i)^2##, you have to expand the sum
\left(\sum_i (a_i-t)\right)^2 = \left( \sum_i a_i - nt \right)^2 <br /> = \sum_i a_i^2 + 2\sum_{i&lt;j} a_i a_j - 2nt \sum_i a_i + n^2 t^2.
JulmaJuha said:
(\sum_{j=1}^{n}(\Delta X_j)^4 + 2*\sum_{i=1}^{n}\sum_{j&lt;i}^{ }(\Delta X_i)^2(\Delta X_j)^2 -2*t*\sum_{j=1}^{n}(\Delta X_j)^2+t^2
Good lord! I must be going mad or selectively blind. I swear when I read this last night the second term did not have a factor of 2! :confused:
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
