Calculating the Velocity of a Fireman Sliding Down a Pole
In summary, when a fireman of mass (m) slides down a pole a distance (d) with negligible air resistance and starting from rest, he will have the same speed at the bottom as if he had stepped off a platform a distance (h) above the ground. To find the speed of the fireman when he is a distance (y) above the bottom of the pole, we can use the conservation of energy equation, setting the initial kinetic energy and potential energy at the top of the pole equal to the kinetic energy and potential energy at a distance (y) from the bottom of the pole. This leads to the equation v=(2g(2h-d))^0.5, where g is the acceleration due to gravity
CheeseJam
A fireman of mass (m) slides a distance (d) down a pole. He starts from rest. He moves as fast at the bottom as if he had stepped off a platform a distance h) <(or equal to) (d) above the ground and descended with negligible air resistance.
In terms of (g), (h), and (d), what is the speed of the fireman when he is a distance (y) above the bottom of the pole?
KE=1/2mv^2
PE=mgh
I tried setting KE=PE and making height equal to: h/d-y, but that didn't work. Any ideas? Thanks.
Total Energy remains constant so:
KE_Top + PE_Top = KE_y + PE_y
0 + mgh = 0.5mv^2 + mgy
mg(h-y)=0.5mv^2
2g(h-y)=v^2
v=(2g(h-y)^0.5
y=d-h
Therefore
v=(2g(h-(d-h))^0.5
=(2g(2h-d))^0.5
Is my best bet.
What is the average speed of a fireman sliding down a pole?
The average speed of a fireman sliding down a pole varies depending on the height of the pole and the weight of the fireman. However, on average, a fireman can slide down a pole at a speed of 10-15 feet per second.
How does a fireman control their speed while sliding down a pole?
A fireman can control their speed by gripping the pole tightly with their hands and using their legs to increase or decrease pressure on the pole. By adjusting the pressure, they can slow down or speed up their descent.
What is the physics behind a fireman sliding down a pole?
The physics behind a fireman sliding down a pole involves friction and gravity. When the fireman's hands and legs grip the pole, friction is created, which helps them control their speed. Gravity pulls them down the pole, accelerating their descent.
What safety precautions do firemen take when sliding down a pole?
Firemen are trained to slide down a pole safely. They wear protective gear, such as gloves, to avoid friction burns on their hands. They also ensure that the pole is free of any obstructions or debris that could cause them to lose control.
Can anyone slide down a pole like a fireman?
No, not everyone can slide down a pole like a fireman. It takes proper training and physical strength to be able to control your descent and avoid injury. Firemen undergo rigorous training to learn how to slide down a pole safely and efficiently.
