First Order Differential Equation Problem
th3plan
A 14 lb weight attached to the end of spring stretches it 4 in. Find the equation of motion if the weight is released from rest at a point 3 inches above equilibrium position
F=kx
mx''+kx=0
ok I need some help just finding out what the k constant is. I know I use hooks Law F=kx, and F is mg=kx. Do i consideer equilibrium when nothing is attached to it, and that is y=0? Then what is the x considered in Hooks Law equation mg=kx , is it the distant its stretched from equilibrium position ?
Thanks
First, this is a undamped second order problem.
I would consider equilibrium is when mg=kx.
F=kx
mx''+kx=0
Thanks
now what do u mean by equillibrium, is that when its unstretched and no wait? or the differecne between unstretrched and stretches in the middle in other words ?
when the spring is stretched (downward) to x_0 such that kx_0=mg, it's equillibrium, that's y=0.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
