Fission or Fussion on Lead to release energy?
Lead is not used as fuel in nuclear power plants but serves to slow down and stop fission or fusion reactions. Fission typically occurs with heavy elements like uranium, while fusion generally involves lighter elements such as hydrogen. Stable atoms, including lead, require significant energy to undergo fission or fusion, making such reactions impractical for them. The discussion highlights that energy is released during fission of uranium and fusion of hydrogen, while elements like iron do not yield energy through either process. Currently, there are no operational fusion power plants globally.
Phycisists
How is Lead being used in a nuclear power plant, is it done by the fission process or fussion? No equations are needed as this is an introductionary question into the atomic structures.
Are the stable atoms unable to undergo fission/fussion?
Please explain to me, how do I know if fission or fussion can release energy from a substance
I won't say that "stable atoms" are not able to under go fission or fusion, but the energy required to make them fission or fusion is far greater than that would be gotten out of such a reaction. Lead is used to slow down and stop a fission or fusion reaction.
I'm not sure if I entirely understand this but, can only heavy nucleus like Lead be processed through fission, and smaller nucleus through fusion as they combine? In that case Lead is fusion? Where's the limit on the amounts of protons/neutrons in that case?
When you look at the nuclear binding energy you can see that fusing hydrogen releases energy and that fissioning unranium releases energy. In between on the graph is iron and several other elements where fusion nor fission will release much if any energy and in fact you have to put energy into the act.
Heavy elements are created in supernova stars because they can put in the energy to fuse elements greater than iron-56 and that's how uranium and others were created.
http://en.wikipedia.org/wiki/Supernova_nucleosynthesis
The OP's question asked how lead is used in a nuclear power plant. AFAIK, lead is not used as fuel, but for another essential purpose. Can anyone guess what this purpose is?
Currently, there are no fusion power plants operating in the world.
