mich said:
I wasn't speaking of two sources for simplicity sake. Just imagine the M&M experiment performed on one frame, where we all know the result will be null.
But now imagine a second observer …….
NO that is not true.
Your problem is not in understanding SR. It is that you do not understand MM in the first place.
You need to get that straight first, and you won’t do that by applying SR when you clearly do not understand either M&M or SR.
M&M did not need to “a second observer” they used one observer making two observations (horizontal & vertical) and changed the direction of motion for that one observer (horizontal or vertical).
MOST important! M&M did not agree that “we all know the result will be null” as you claim; you need to show why you think M&M expected a “null result”.
As you look at the details of exactly how
M&M expected a NON-Null result you should see why the geometry you just provided for your relativistic length and time calculations is just plain wrong.
Don’t start with the relativistic solution – start by understanding the Math and Geometry used to show the
M&M expectation of a Non-Null result.
Once your straight on two things
1) how they made the Non-Null Result predictions and
2) ALL their observations showed Null Results
you will then understand the paradox they and science had to deal with.
THEN apply the relativistic solution to the M&M math and geometry to solve the paradox.
(Note: according to Lorentz himself the SR relativistic solution was a more complete solution to the paradox than his Lorentz solution as the SR version introduced time dilation and the simultaneity issue. I.E. Lorentz does not include “simultaneity” only SR re-interpretations of Lorentz can apply “simultaneity”)
When you get your geometry and math correct to follow M&M you will see that only using relativistic SR can you predict a Null Result as observed; in contrast to the classical Non-Null results predicted by M&M that did not match the observations.
As this is the third time I’ve pointed you to this flaw in your approach – I trust you will take the time to research and ruminate on this one point. And then proceed with further application of what you learn about SR from that.
If you do that I’m confident you will need no additional help understanding the foundation of SR correctly. So I’ll unsubscribe from this thread and see you in another as you move on to more advanced topics.
