Calculate Inlet/Outlet Gas Relative Humidities
  • Thread starter missmaria
  • Tags
    Adsorption
In summary, the purpose of calculating inlet/outlet gas relative humidities is to determine the amount of water vapor present in a gas mixture. This information is important in various scientific and industrial processes, such as air conditioning, drying, and combustion, as well as in weather forecasting. The inlet/outlet gas relative humidity is typically calculated using the formula: RH = (actual water vapor pressure / saturation vapor pressure) x 100%. The actual water vapor pressure can be measured using a hygrometer, while the saturation vapor pressure can be determined using temperature and pressure data. The main factors that can affect the inlet/outlet gas relative humidity include temperature, pressure, and the amount of water vapor present in the gas mixture. It is important to consider
missmaria
Air is compressed to 10 atmospheres, cooled to 25 degrees C and passed through a bed of molecular sieve that has an initial moisture content of 8 lb water/100 lb sieve. the saturation vapor pressure of water at 25C is 24 mmHg. Assume M.W of air is 30 and the height of a transfer unit is 3 inches. How can i calculate the inlet and outlet gas relative humidities?
You should use Fick's first laws and set up some mass balance for the mass transfer. Take the following source for some caluclated examples: http://www.composite-agency.com" . Regards, Hedenqvist
To calculate the inlet and outlet gas relative humidities, we can use the following formula:
RH = (Pv/Pvs) * 100
Where:
RH = Relative humidity (in %)
Pv = Partial pressure of water vapor (in mmHg)
Pvs = Saturation vapor pressure of water at the given temperature (in mmHg)
For the inlet gas, we can use the following steps:
Step 1: Calculate the partial pressure of water vapor in the inlet gas.
Pv = (8 lb water/100 lb sieve) * (24 mmHg/1 lb water) = 1.92 mmHg
Step 2: Calculate the saturation vapor pressure of water at 25C.
Pvs = 24 mmHg
Step 3: Calculate the relative humidity of the inlet gas.
RH = (1.92 mmHg/24 mmHg) * 100 = 8%
Therefore, the inlet gas has a relative humidity of 8%.
For the outlet gas, we can use the following steps:
Step 1: Calculate the partial pressure of water vapor in the outlet gas.
Pv = (1.92 mmHg) * (30/10 atmospheres) = 5.76 mmHg
Pvs = 24 mmHg
Step 3: Calculate the relative humidity of the outlet gas.
RH = (5.76 mmHg/24 mmHg) * 100 = 24%
Therefore, the outlet gas has a relative humidity of 24%.
It is also worth noting that the height of a transfer unit of 3 inches may affect the calculation of relative humidity, but without further information about the system, it is difficult to accurately account for this factor.
1. What is the purpose of calculating inlet/outlet gas relative humidities?
The purpose of calculating inlet/outlet gas relative humidities is to determine the amount of water vapor present in a gas mixture. This information is important in various scientific and industrial processes, such as air conditioning, drying, and combustion, as well as in weather forecasting.
2. How is the inlet/outlet gas relative humidity calculated?
3. What factors can affect the inlet/outlet gas relative humidity?
The main factors that can affect the inlet/outlet gas relative humidity include temperature, pressure, and the amount of water vapor present in the gas mixture. Changes in these parameters can result in fluctuations in the relative humidity of the gas.
4. Why is it important to consider the inlet/outlet gas relative humidity in scientific experiments?
The inlet/outlet gas relative humidity is important to consider in scientific experiments because it can affect the accuracy and reliability of the results. In some experiments, the presence of water vapor can also influence the reaction rates and product yields, making it a critical factor to control and monitor.
5. How can the inlet/outlet gas relative humidity be controlled or adjusted?
The inlet/outlet gas relative humidity can be controlled or adjusted by manipulating the temperature, pressure, and water vapor content of the gas mixture. This can be done using various techniques such as heating, cooling, humidification, and dehumidification, depending on the specific needs of the experiment or process.
  • Mechanical Engineering
  • Materials and Chemical Engineering
  • Electromagnetism
