Flat plate heat exchanger - Hand calculations help
The discussion focuses on designing a flat plate heat exchanger, emphasizing the importance of hand calculations using the Log Mean Temperature Difference (LMTD) and Effectiveness-NTU (E-NTU) methods. Key parameters such as the area and number of plates are critical for these calculations. Participants recommend specific resources, including a datasheet from GEA and an introductory document from Xetex, to assist in the design process. The urgency of the project deadline highlights the need for efficient and accurate calculations.
  • Understanding of Log Mean Temperature Difference (LMTD) method
  • Familiarity with Effectiveness-NTU (E-NTU) method
  • Knowledge of heat exchanger design parameters
  • Basic thermodynamics, including specific heat concepts
  • Study the LMTD method for calculating heat exchanger performance
  • Explore the E-NTU method for analyzing heat exchanger effectiveness
  • Research flat plate heat exchanger design parameters and calculations
  • Review the provided GEA datasheet and Xetex introduction for practical insights
Engineers, thermal system designers, and students involved in heat exchanger design and analysis will benefit from this discussion, particularly those needing to perform hand calculations for flat plate heat exchangers.
MechEngFrank
I am designing a flat plate heat exchanger for a project and I am not sure where to start with the hand calculations, specifically the LMTD and E-NTU methods, also how to work out the parameters which i will need to complete these methods such as area and number of plates. My deadline is soon, any help is much appreciated.
Perhaps you could begin by giving us a bit more information. ie. the temperatures involved (temperature of the thing being cooled and the initial temperature of the coolant - presumably air), and the specific heat of the coolant.
AM
I would suggest this link will prove to be more usefull to you for getting the desired heat heat exchanger. http://www.gea-phe.com/fileadmin/user_upload/documents/product_datasheets/NA_FP_CH_usa.pdf
For more detailed analysis and design you can refer.
http://www.xetexinc.com/uploaded/Doc/2-2%20Flat%20Plate%20Heat%20Exchangers%20-%20An%20Introduction%20v2.1.pdf
  • · Replies 34 ·
