What does it mean for the universe to be "flat"?
In summary, a "flat" universe means it can be described using Euclidean geometry and the equations for areas and volumes of shapes we learned in school. This is in contrast to a curved universe where these equations wouldn't work. It's difficult for humans to imagine things in higher dimensions, so a 3-D analogy is often used. Just like a 2-D person living on the surface of a balloon wouldn't be able to see the curvature, we are only able to observe a small portion of the universe and it appears flat to us. This concept is related to the idea of inflation, where the universe expanded so much that its geometry appears flat to us.
UrbanXrisis
1,196
what does it mean for the universe to be "flat"?
What is the difference if the universe was flat or curved at all?
Astronomy news on Phys.org
The geodesic lines are linear in flat space.
A "flat" universe is basically one that can be described with Euclidean geometry. In other words, it means that you can use those ordinary equations for the areas and volumes of spheres, cubes, etc. that you learned in grade school. If it were curved, then you'd find, for example, that the pythagorean theorem didn't work on triangles (though you probably wouldn't notice unless your triangle was really big).
It's impossible for humans to imagine things in 4-D, so it's best to think of the 3-D analogy. Imagine you're a 2-D person living on the surface of a balloon. Since you're a 2-D person, you can't see that third dimension in which the balloon is curved, so you probably assume that normal euclidean geometry will work to describe the size of your triangular house -- it's a right triangle, cause that's what all the upper class 2-D people live in over in two-dimensional suburbia. But one day, you go out and actually measure its sides and...*gasp*... [tex]a^2+b^2 \ne c^2[/tex].
How can this be? It's because the surface you're living on is curved and the equations that describe spherical triangles are different from those that describe flat ones. But let's say that there's another 2-D person who's living on a piece of paper over in Chicago. This person is living on a flat surface, so they will measure their right triangle house to obey the Pythagorean theorem and everything will seem normal (or, at least, as normal as possible for someone living in Chicago).
Consider one last analogy. Imagine we're back to the person on the surface of the balloon, but imagine this time that the balloon is much, MUCH larger than the 2-D person (or even their observable universe). In this case, the surface they're living on would be curved, but they wouldn't be able to tell because they would only be able to measure a very small portion of the balloon and, to the accuracy with which they can measure, that portion would appear flat (same basic reason that the Earth appears flat to someone living on it).
The reason I give the last analogy is that it describes the basic idea behind inflation. That is, the universe appears flat because we're only observing a very small portion of it. It suggests that, at some point, the "balloon" that is our universe expanded so much that the geometry in the present day observable universe is, for all intents and purposes, flat.
Keep in mind that this is just an analogy and that you have to add a dimension (specifically, a time-like one) in order for it to apply to cosmology.
1. What is a "flat universe"?
A "flat universe" refers to the concept in cosmology that the universe has a flat geometry, meaning that the amount of matter and energy in the universe is just enough to make the universe expand at a steady rate without collapsing or accelerating.
2. How do scientists determine if the universe is flat or not?
Scientists use various methods to determine if the universe is flat, including measuring the cosmic microwave background radiation, observing the large-scale structure of the universe, and studying the expansion rate of the universe.
3. What are the implications of a flat universe?
If the universe is flat, it suggests that the universe is infinite and will continue to expand at a constant rate forever. It also supports the idea that the universe is composed of mostly dark energy and dark matter.
4. Is there evidence to support the idea of a flat universe?
Yes, there is strong evidence to support the idea of a flat universe. Observations of the cosmic microwave background radiation, the large-scale structure of the universe, and the expansion rate of the universe all point towards a flat universe.
5. What are some alternative theories to a flat universe?
Some alternative theories to a flat universe include the "open universe" theory, which suggests that the universe will continue to expand forever, but at an accelerating rate, and the "closed universe" theory, which proposes that the universe will eventually collapse in on itself due to gravity.
  • Astronomy and Astrophysics
  • Cosmology
