1oldman2
- 1,450
- 1,210
That sounds as if they've still not cracked booster reuse of the higher delta-v missions: too much heating or too little return fuel available.1oldman2 said:Apparently not quite "flawless". but they did get it on the barge.
http://news.discovery.com/space/pri...-spacex-rocket-suffered-max-damage-160518.htm
This flight profile apparently heat was the issue, about four or more times the normal load.mheslep said:That sounds as if they've still not cracked booster reuse of the higher delta-v missions: too much heating or too little return fuel available.
Yes, as I said this flight had a more challenging orbit requiring more velocity. That class of satellites appear beyond reach of reusable boosters with the current SpaceX booster design or configuration.1oldman2 said:This flight profile apparently heat was the issue, about four or more times the normal load.
http://www.firstcoastnews.com/news/local/spacex-falcon-9-first-stage-booster-suffered-max-damage-on-landing/207178195
And likely a rocket crash from time to time.rootone said:Good job.
Looks like the barge has to be designed to dissipate a lot of sudden heating and gas presure.
Sure enough, there it is. In all the Apollo landings I have watched I had never considered the LM's suspension, thanks for pointing this out.CWatters said:As I recall a similar honeycomb was used in thesuspension legs of the Apollo moon landers. I suspect it's just a matter of changing the shock absorber bit like you can do on a car.
