How Do You Solve This Floor Function Equation?
In summary, the floor function challenge is a mathematical problem that involves finding the greatest integer less than or equal to a given number. It can be solved using the floor function, which is often used in computer programming. Some real-world applications of this challenge include financial calculations, game development, and data science. The main difference between the floor function and the ceiling function is that the former rounds down to the nearest integer while the latter rounds up. However, there are some limitations to using the floor function, such as unexpected results with negative numbers and the inability to round to other decimal places.
anemone
MHB
POTW Director
3,883
115
Solve the equation $\left\lfloor{\dfrac{2a + 1}{a^2+ 1}}\right\rfloor\left\{\dfrac{a^2+ 2a +2}{a^2+ 1}\right\}=\dfrac{2a -a^2}{a^2 + 1}$, where $\{a\}$ denotes the fractional part of $a$.
Mathematics news on Phys.org
My attempt:
\[\left \lfloor \frac{2a+1}{a^2+1} \right \rfloor\left \{ \frac{a^2+2a+2}{a^2+1} \right \}=\frac{2a-a^2}{a^2+1}\\\\ \left \lfloor \frac{2a+1}{a^2+1} \right \rfloor\left \{ \frac{a^2+1+2a+1}{a^2+1} \right \}=\frac{2a+1-(a^2+1)}{a^2+1}\\\\ \left \lfloor \frac{2a+1}{a^2+1} \right \rfloor\left \{ \frac{2a+1}{a^2+1} \right \}=\frac{2a+1}{a^2+1}-1\]
Let $q(a) = \frac{2a+1}{a^2+1}$
The function $q$ has two extrema and two asymptotes: View attachment 4761
From the graph it is obvious, that $q$´s range is included in the open interval $(-1,2)$:
\[q: \mathbb{R}\rightarrow Y \subset (-1;2)\]
If $|q| < 1$ there is no solution, because:
\[\left \lfloor q \right \rfloor\left \{ q \right \}=0\cdot q \neq q-1\;\;\; 0 \le q<1\]
And
\[\left \lfloor q \right \rfloor\left \{ q \right \}=(-1)\cdot q \neq q-1 \;\;\; -1<q < 0\]
If $1 \le q < 2$ (for $0 \le a \le 2$) you get:
\[\left \lfloor q \right \rfloor\left \{ q \right \}=(+1)\cdot (q-1) = q-1\]
So the set, $S$, of solutions is: \[S=\left \{ a \in \mathbb{R}\: \: \: |\: \: \: 0 \le a \le 2 \right \}\]
Well done, lfdahl, and thanks for participating!:)
My solution:
$\left\lfloor{\dfrac{2a + 1}{a^2+ 1}}\right\rfloor\left\{1+\dfrac{2a +1}{a^2+ 1}\right\}=\dfrac{2a+1 -a^2-1}{a^2 + 1}$
$\left\lfloor{\dfrac{2a + 1}{a^2+ 1}}\right\rfloor\left\{\dfrac{2a +1}{a^2+ 1}\right\}=\dfrac{2a+1}{a^2 + 1}-1$
$\left\lfloor{\dfrac{2a + 1}{a^2+ 1}}\right\rfloor\left\{\dfrac{2a +1}{a^2+ 1}\right\}=\left\lfloor{\dfrac{2a + 1}{a^2+ 1}}\right\rfloor+\left\{\dfrac{2a +1}{a^2+ 1}\right\}-1$
$1-\left\{\dfrac{2a +1}{a^2+ 1}\right\}=\left\lfloor{\dfrac{2a + 1}{a^2+ 1}}\right\rfloor-\left\lfloor{\dfrac{2a + 1}{a^2+ 1}}\right\rfloor\left\{\dfrac{2a +1}{a^2+ 1}\right\}$
$1-\left\{\dfrac{2a +1}{a^2+ 1}\right\}=\left\lfloor{\dfrac{2a + 1}{a^2+ 1}}\right\rfloor\left(1-\left\{\dfrac{2a +1}{a^2+ 1}\right\}\right)$
$1=\left\lfloor{\dfrac{2a + 1}{a^2+ 1}}\right\rfloor$
Solving it for $x$ we get $\{x:0≤ x≤ 2\}$
Related to How Do You Solve This Floor Function Equation?
What is the floor function challenge?
The floor function challenge is a mathematical problem that involves finding the greatest integer less than or equal to a given number. It is often used in computer programming to round down a number to the nearest integer.
How do you solve the floor function challenge?
The floor function challenge can be solved by using the floor function, also known as the greatest integer function. This function can be implemented in various programming languages, such as JavaScript and Python, using the Math.floor() or math.floor() methods respectively.
What are some real-world applications of the floor function challenge?
The floor function challenge has various real-world applications, such as in financial calculations where rounding down is needed, in game development to calculate hit points or scores, and in data science for data manipulation and analysis.
What is the difference between the floor function and the ceiling function?
The floor function and ceiling function are both mathematical functions that involve rounding numbers. The floor function rounds a number down to the nearest integer, while the ceiling function rounds a number up to the nearest integer. For example, the floor of 5.6 is 5, while the ceiling of 5.6 is 6.
Are there any challenges or limitations to using the floor function?
One of the challenges of using the floor function is that it can sometimes produce unexpected results when working with negative numbers. For example, the floor of -5.6 is -6, which may not be the desired result. Additionally, the floor function only rounds down to the nearest integer, so it cannot handle other types of rounding, such as rounding to the nearest decimal place.
  • General Math
  • General Math
  • General Math
