Fluid dynamics and pressure type question.
To determine if water can be pumped from a 55-gallon drum back to a roof deck, calculating the pressure in pascals is essential. The pressure is influenced by the weight density of the water and the height it needs to reach. However, the geometry of the hose, particularly its diameter, significantly affects the flow and pressure dynamics. Concentrating a large pressure into a small hose can lead to inefficiencies and may not provide sufficient force to move the water uphill. Therefore, the design must consider both pressure calculations and the impact of hose geometry on water flow.
Gersty
Let's say I want to install a 55 gallon drum on the ground to collect rain water as it runs off the roof. What if for some strange reason I wanted to run a hose from a spigot in the bottom of the drum back up to water the plants on the roof deck (I'm looking into green roofs). Could we just calculae the pressure in pascals and then determine if that would be enough force to push a hosefull of water back up to the roof?
Pressure is just the weight density times height. Geometry - such as concentrating a large pressure into a small hose - plays no role whatsoever, so what you are describing can't be done.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
