What Is the Volume Flow Rate of a Water Jet Impacting a Scale?
gikwiye
a vertical, 1cm-diameter jet of water impinges upon a bathroom scale such that the latter exhibits a reading of 5 kg. Estimate the volume flow rate of the jet.
p=F/A
Q(volume flow rate)=U*A(area where the jet of water is applied on)
a=pi*r²
F=mg
P=(rho*U²)/2 (if we consider that the pressure applied on the scale by the jet is essentially dynamic pressure) (don't know if this is correct though)
let's calculate A first
A=2.5x10^(-5)*pi
then let's change the kg into Newtons:
F=5*9.81=49.05N
P is F/A therefore: P=49.05/(2.5*10^(-5))=624.523kpa
with P=(rho*U²)/2 if find U=35.341m/s
and with
I find Q=2.7756 l/s
just want to know if I should include the atmospheric pressure or not
found it
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
