Can Suction Lift a 20 Meter Water Column Without Exceeding Its Tensile Strength?
Namrata
What suction (or negative pressure) is required to support a column of liquid 20 m high? Does this exceed the tensile strength of water?
Bulk Modulus = (Change in Pressure/ (Change in Volume/Volume))
Pressure = Force / Area
Tensile strength of water = 20 MPa
Assume column has a diameter of 1 unit.
The surface area of this column is thus:
Circumference x Height of column + Area of top of column
= 62.83 + 0.79
=63.62 units2
Do you know why water rises in a straw when you suck on it?
If you do, then assuming that you have an extremely long straw, can you calculate how high the water would rise if you had perfect vacuum (zero pressure) inside the straw?
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
