Fluid mechanics suction question
In centrifugal pumps, the diameter of the delivery pipe is smaller than that of the suction pipe primarily due to the principle of continuity, which states that fluid velocity increases as the cross-sectional area decreases. This design ensures that the pump can deliver fluid at a higher velocity and pressure than it intakes, minimizing pressure losses and ensuring adequate net positive suction head to prevent cavitation. While some pumps, like piston-based ones, may not accelerate flow in the same way, centrifugal pumps inherently increase fluid velocity within the pump mechanism. The smaller outlet diameter allows for efficient fluid acceleration, which is crucial for effective pump operation. Understanding these dynamics is essential for optimizing pump performance in various applications.
de$per@do
In centrifugal pumps why diameter of delivery pipe is smaller than suction pipe?
It might have to do with Bernoulli's principle , The smaller outlet will have a higher flow velocity and reduced pressure . But I am not 100% positive.
It's more to do with simple continuity. Centrifugal pumps deliver fluid at a higher velocity than they intake, so assuming incompressibility (a decent assumption for pretty much all applications with centrifugal pumps), the diameter at the outlet must be smaller than at the inlet since the volumetric flowrate is unchanged and the velocity has increased.
cjl said:
... Centrifugal pumps deliver fluid at a higher velocity than they intake, ...
Well, pumps deliver at higher pressure than they intake. The outlet piping velocity will be dependent on the outlet pipe area (due to continuity), not the other way around.
The reason inlet piping is usually larger diameter than outlet piping is to minimize pressure losses upstream of the pump, in order to ensure the pump has adequate net positive suction head (to minimize cavitation in the pump).
True, but some pumps directly increase the pressure of the flow. An example of this is pretty much any piston based pump - the outlet of the pump tends to be about the same velocity as the inlet, but at a significantly increased pressure (which of course can be traded for velocity easily enough). The pump does not inherently accelerate the flow, although it can be used to accelerate the flow if the pump is in conjunction with a nozzle. Centrifugal pumps accelerate the fluid significantly within the pump itself, so at the exit of the pumping mechanism, the flow is much faster than the inlet. You could indeed slow the flow down through a diffuser and then have an outlet that is the same size as the inlet, but the pump's mechanism inherently accelerates the flow. As a result, the outlet tends to be smaller than the inlet.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
