Calculating Hydraulic Jump with Unknown Cross Sectional Area: Help Needed
The discussion centers on calculating hydraulic jump using the equation V1(b1h1) = V1(b2h2) while solving for h2. The user expresses confusion over the assumption made in the solution manual regarding the base measurement of the cross-sectional area of the water, specifically questioning the validity of canceling out the bases of different stream sizes. The user asserts that the smaller stream must have a smaller base than the larger stream, indicating a fundamental misunderstanding of the hydraulic principles involved. A request for a diagram to clarify the concept is also made.
  • Understanding of hydraulic jump principles
  • Familiarity with fluid dynamics equations
  • Knowledge of cross-sectional area calculations
  • Ability to interpret hydraulic diagrams
  • Study the principles of hydraulic jump in fluid dynamics
  • Learn about the implications of cross-sectional area in flow calculations
  • Research the derivation and application of the equation V1(b1h1) = V1(b2h2)
  • Explore resources on creating and interpreting hydraulic diagrams
Students and professionals in civil engineering, hydraulic engineering, and fluid mechanics who are involved in analyzing flow behavior in channels and reservoirs.
LT72884
A hydraulic jump (see Video V10.11) is in place downstream
from a spillway as indicated in Fig. P5.10. Upstream of
the jump, the depth of the stream is 0.6 ft and the average stream
velocity is 18 ft/s. Just downstream of the jump, the average stream
velocity is 3.4 ft/s. Calculate the depth of the stream, h, just downstream
of the jump.
Q1=Q2 or V1A1=V2A2 where A is the cross sectional area of the water.
I have 90% of this done. When i looked in my manual i noticed an odd jump they made and i don't get why. that is where i need the help
V1(b1h1) = V1(b2h2)
Im solving for h2.
What i can't figure out is what to use for the base measurement of the cross section of the water. i have no idea how wide the reservoir channel is. It never gave me that number and we can't just "assume" that the base is the same in the smaller stream than it is in the larger stream. But the solution manual made that assumption so that the bases cancel out. I disagree with that. Since the stream IS SMALLER, therefore it has a smaller base than the larger stream at the bottom... Canceling out the bases can't work.
thanks for the help:)
Could you post a diagram?
  • · Replies 0 ·
