How Can I Calculate Flywheel Spin-Up Time for Various Mass and Shape Options?
  • Thread starter Thread starter TheSilverhead
    Calculations
To calculate the flywheel spin-up time, key variables include the motor's RPM, torque, flywheel mass, shape, and diameter. The discussion highlights that for an idealized electric motor, peak torque occurs at zero RPM, leading to finite time to reach near-max RPM but potentially infinite time for max RPM. The flywheel's primary advantage is moderating RPM swings during item propulsion, rather than maximizing stored energy. The formula for angular acceleration, torque divided by angular inertia, is essential for calculations. Understanding angular motion principles is crucial for optimizing flywheel performance in propulsion applications.
TheSilverhead
Hello! I've got a problem that I haven't the faintest clue how to go about. I have a flywheel, spinning on a motor's shaft. I want to be able to calculate the time it will take the flywheel to spin up to the motor's max RPM, based off of the variables:
Motor's RPM
Motor's Toque
Flywheel's mass
Flywheel's shape (Solid disk, disk with outer ring, etc.)
Flywheel's diameter.
I have a fixed motor, with enough amperage that it will always be able to draw as much as it needs (from stall.) I'm varying the flywheel's mass and shape to find a good balance of low spin-up time to high stored energy. The flywheels are used to propel items, if it matters.
Thanks!
For an idealized electric motor, peak torque occurs at zero rpm and the torque decreases linearly to zero as rpm increases linearly to max rpm. I'm wondering if in this idealized case, the time to reach max rpm will be infinite (I didn't do the math). The time to reach some rpm close to max rpm will be finite.
Why are you concerned with the flywheel?
You say that your aim is to propel items, sort of a mass driver idea I guess.
The main benefit of the flywheel is to moderate the RPM swing when the ejected mass separates from the launcher. But there is no real advantage to having lots of stored energy in the flywheel otherwise.
Of course you can add some contraption to help transfer the flywheel energy to the 'flight item', but that is a very different discussion.
Not sure if this will help, but take a look if you don't mind:
Angular acceleration = torque / Angular inertia (also known as Moment of inertia)
here is something that will help you out on calculating the angular inertia of your disk: http://hyperphysics.phy-astr.gsu.edu/hbase/icyl.html
Ask for more if you want, angular motion has sort of become my expertise after spending most of my time on this forum for it.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
