What is the relationship between focal length and focal points?
A lens has two focal points but only one focal length, which is defined as the distance from the lens's center to either focal point. If both focal points are 5cm from the lens, the focal length is 5cm, not 10cm. This is because the focal length is measured to a single focal point rather than the sum of both. Understanding this distinction is crucial for applications in optics. The focal length is a key parameter in determining how a lens will focus light.
vetgirl1990
This is a silly question... but I know that a lens has two focal points but one focal length.
If each focal point is at 5cm from the lens, would the focal length be 5cm, or 10cm (adding the position of each focal point together)?
N/A
N/A
