For what value of x will this object first come to rest?
  • Thread starter Thread starter gijungkim
    Rest Value
A 2.0-kg object with an initial velocity of 5.0 m/s experiences a force defined by Fx = (–4.0x) N. The key to solving for the position where the object first comes to rest lies in understanding that the force varies with position, requiring integration to determine the total work done. The initial kinetic energy is calculated as 25 J, and through integration, the work done by the force is found to be -2.0x^2 J. This leads to the conclusion that the object will come to rest at x = 3.5 m. The discussion emphasizes the importance of recognizing that the force is not constant and cannot be simply multiplied by distance to find work.
gijungkim
A 2.0-kg body moving along the x-axis has a velocity vx = 5.0 m/s at x = 0. The only force acting on the object is given by Fx = (–4.0x) N, where x is in m. For what value of x will this object first come (momentarily) to rest?
0.5 mv^2 = KE
F*d = work
Since KE = 0.5 * 2 * 5^2 = 25J
and F*d = -4.0x^2
-4x^2 = 25J
x = 2.5 m
This is how I approached it, but the answer is 3.5m. Can anyone help me out?
Since the force changes with x, what will be the work done by the force when the body moves by a distance dx?
Integrate it to find the total work and the expression you get comes out to be different. why?
you can't find the net work done like this:
gijungkim said:
and F*d = -4.0x^2
everything else is correct. Just the left hand side of the equation.
Oh I got it now
Fxdx = -4.0x dx
W = -2.0x^2 J = 0.5 * 2 * 5^2 J
x = 3.5m right??
Thank you so much!
Likes AdityaDev
The force changes as the position of particle changes. So you can't get the value of work done by simply multiplying F with x.
Likes gijungkim
Got it now! Thank you for helping me!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
