Force Acting on Rope: Homework Solutions
  • Thread starter Thread starter intdx
    Force Rope
The discussion revolves around a physics homework problem involving a 10 kg picture hanging by two ropes. The main questions are whether the forces on ropes A and B are equal and how to calculate the force on rope A. The accepted answer for the force on rope A is 49N, derived from the gravitational force and the angle of the rope, but there is confusion regarding the horizontal component and the overall force distribution. Participants suggest using Lami's theorem and resolving the weight into components to understand the equilibrium better. The conversation highlights the need for clarity in visualizing the forces acting on the ropes to solve the problem accurately.
intdx
From http://library.thinkquest.org/10796/index.html (#6b, 6c)
A 10 kg picture is hanging on a wall by two ropes.
http://library.thinkquest.org/10796/ch5/IMG00008.GIF
b. Are the forces acting on the ropes A and B equal in magnitude?
c. How big is the force acting on the rope A?
The site accepts the answer 49N for #6c, but I'm not sure why.
F_g=mg
F=\sqrt{F_x^2+F_y^2}
F_x=F\times \cos \theta
The answer for #6c appears to be equal to
10\textrm{kg}\times 9.80\textrm{m/s}^2\times \textrm{cos }60^\circ=49\textrm{N,}
but that doesn't make sense to me; shouldn't we combine the weight of the picture with the rightward pull? In that case, how do we find the rightward pull?
Or, is there an imaginary diagonal force--equal in magnitude to the gravitational force--of which we want the horizontal component? In that case, why?
The answer to #6b is "No," but I'm not sure why. (I'm guessing that once I understand #6c, then #6b will follow.)
Thank you!
Actually, I suppose that combining the force of gravity in this case (98N) with a horizontal vector couldn't reduce the magnitude to just 49N...
Is it the second option that I proposed, then? \sqrt{F_g^2\ \textrm{cos}^2\theta +F_g^2\ \textrm{cos}^2(90^\circ-\theta)}=F_g\textrm{,} so it seems plausible. The forces on the ropes, not including from the wall or ceiling where they're above, should add up to the force exerted by the picture, right?
Still, even if I've found the way to do the problem, I don't feel like I have a sufficient understanding of it.
You can resolve mg to 2 components of opposing direction to A and B since they are 90° apart.
To me it is mgCos30°.
I'm sorry; I don't understand what you mean. Would you mind drawing it?
Would it be something like this?
mg\textrm{cos(30}^\circ \textrm{)}
EDIT - whoops, sorry, I edited without realizing you had posted again.
Just extend line A and B downward. These 2 directions can be components of mg.
Hello intdx,
Try Lami's theorem here.Or otherwise resolve the weight along OA and OB to check for equilibrium.
regards
Yukoel
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
