Force at an Angle: Solving for Acceleration & Normal Force
  • Thread starter Thread starter EnDev
    Angle Force
A 70 kg box is pulled across a frictionless surface by a 300 N force at a 30-degree angle to the horizontal. The acceleration of the box in the X direction is calculated to be 3.71 m/s². The normal force acting on the box is determined to be 536 N. The solution involves applying the correct physics equations to resolve the forces acting on the box. Understanding the components of the applied force is crucial for solving such problems.
EnDev
http://puu.sh/25OuR
a 70kg box is pulled across a frictionlesssurface by a 300N forace at an angle of 30 degree to the horizontal
A. What is the acceleration of the box in the X direction
b. what is the normal force on the box
not sure
Im not sure which formula to use on this one..
nevermind i figured it out.
A = 3.71 m/s
B 536
