Force due to Collision and Acceleration Problems
The forum discussion focuses on calculating the average force exerted by a baseball on a fielder's glove during a collision, using the equation F=ma. The user initially miscalculated the force as -574358.97 N but later corrected it to 574.36 N by properly applying the formula with the correct mass conversion from grams to kilograms. Additionally, the discussion touches on free fall acceleration, confirming that it is equal to -9.8 m/s², and explores the relationship between velocity and acceleration. The user also seeks assistance with calculating the speed of water impacting a water wheel, utilizing the principles of energy conservation.
  • Understanding of Newton's Second Law (F=ma)
  • Basic kinematics, including equations of motion
  • Concept of gravitational acceleration (g = 9.8 m/s²)
  • Knowledge of energy conservation principles in physics
  • Study the derivation and application of the impulse-momentum theorem
  • Learn about energy transformations in mechanical systems
  • Explore advanced kinematics problems involving free fall and projectile motion
  • Investigate the principles of power output in mechanical systems, particularly in water wheels
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to clarify concepts of force, motion, and energy transfer in real-world applications.
psuedodragon
1. A baseball (m=140g) traveling 32 m/s moves a fielder's glove backward 25 cm when the ball is caught. What was the average force exerted by the ball on the glove?
The only equation I can find in my notes that doesn't ask for the m of the glove is
F=ma=m[(v2-v1)/t]
Then for velocity its v=delta x/delta t
v=x/t -> t=x/v=.25m/32 m/s =0.0078s
F=(140g)(0-32 m/s /0.0078s) = -574358.97
which I'm pretty sure is wrong... yet I'm not sure where I went wrong, or if I was even on the right track in the first place...
And random other question:
If you drop an object, what's the formula to figure out its acceleration? I mean, it has something to do with the weight as well as g, but I don't think it's a=mg, is it? (considering W=mgh, it just doesn't seem right to me)
I can answer your random question (i'll also take a look at the actual problem to see if I can contribute any insight) but a_{y}=-g which means that acceleration taking place during a free fall is equal to negative gravity or -9.8 m/s^{2}
Or just 9.8 if I decide that down is my positive value and up is the negative... (my prof likes elevator questions for some reason, so we do a lot of positive downward directions)
Anyway, then that means I did a couple of my other questions correctly (wonder of wonder)
But... is it possible for velocity to equal acceleration?
Now keep in mind that velocity and acceleration two different things. One measures the change in distance over a period of time and the other is the change in velocity over a period of time. Hence the units of measure being m/s and m/s^{2} respectively. So, to answer your question in a rather round about question, velocity and acceleration can have the same values but that does not mean they equal each other.
Okay, I just have this question where:
Water falls onto a water wheel from a height of 2.0 m at a rate of 95kg/s. (a) If
this water wheel is set up to provide electricity output, what is its maximum
power output? (b) What is the speed of the water as it hits the wheel?
I got a fine, (P=W/t=mgh/t=(95kg)(9.8m/s^2)(2.0m)/1s= 1862 J/s) but its b that messes with me...
I think I just have problems with speed and acceleration... >.>
ooh, okay... mini brainwave...
F= ma= m(delta v/delta t) when delta t= delta x/v
So:
F= 0.14kg(0-(-32m/s)/0.0078s)= 574.36N
Does that look better than my original -574358.97N? lol
Still don't know how to do the water wheel part b question... :S
ok, I'm just going to type in exactly what I wrote down on my scratch paper.
Given:
\Delta Y = 2 m
v_{i} = 0 m/s
95 kg/s = rate
g = -9.8 m/s^{2}
Find: v_{f}
Solution:
v_{fy}^2 - v_{iy}^2 = -2g\Delta Y
v_{fy}^2 = -2g\Delta Y + v_{iy}^2
v_{fy}^2 = -2(-9.8)(2) + (0)^2
v_{fy} = \sqrt{-2(-9.8)(2)}
v_{fy} = 6.26 m/s
given:
m=140gm=.14kg
u=32m/s
v=0m/s
a=?
s=25cm=.25m
f=m*awe will get the value of acceleration by the formula
v^2=u^2+2asnow calculate and simply put the values u get the answer...
  • · Replies 27 ·
  • · Replies 42 ·
16K
