Force exerted by external field
  • Thread starter Thread starter randomss444
    Field Force
A uniform electric field can counteract the gravitational force on a proton, making it effectively weightless. To find the strength of the electric field required, the equation E = mg/q is used, where m is the mass of the proton, g is the acceleration due to gravity, and q is the charge of the proton. The forces due to gravity and the electric field must be equal and opposite for the proton to achieve weightlessness. The direction of the forces can be assigned positive or negative values based on the chosen coordinate system, but the key is that they must cancel each other out. Ultimately, achieving a net force of zero results in the proton being weightless.
randomss444
A uniform electrical field can exert a force on a charged particle that effectively neutralizes the force of gravity on the particle causing it to be weightless. What is the strength of the electrical field for a proton?
q = 2.45x10^-14
mass of proton = 10.21x10^-12 kg
F=qE
My question is what does that statement make the force?
What I think it means is that gravity is 9.8 m/s^2 so to cancel it out gravity is -9.8m/s^2.
So to sovle it you would use F=mg
so, F = (-9.8m/s^2)(10.21x10^-12 kg)
So Force = -1.00058x^-10
Is that right?
thanks
yes what you have there is essentially correct, just have to take it 1 step further
For the proton to be weightless, the force exerted on the proton by the electric field has to be exactly equal to the force of Gravity.
Force due to Electric Field
F(e) = q * E
Force due to Gravity
F(g) = m * g
So for the proton to be weightless, we have:
F(e) = F(g)
Substituting:
qE = mg
Solve for E
E = mg/q
calculate E and you have the strength of the Electric Field required for the proton to be weightless
Still counfused whether gravity is negative or positive?
Everything else makes sense thanks.
All you want is two forces to cancel.
Force due to gravity is pointing downwards.
So you want Fe to point upwards.
It doesn't really matter if gravity is +ve or -ve
The important thing to realize, as graphene said, is that the two forces are working in opposite directions. Gravity is pulling down, the Electric Field is pushing up.
So for something to be weightless, the force pushing up has to be exactly the same as the force pulling down.
The positive and negative is totally up to you. If you want to call the up direction positive then gravity is negative and the electric force is positive. If you want to call the down direction positive, then gravity is positive and the electric force is negative.
As long as they are opposite and equal the sign doesn't matter because when you add them up, you will get a Net force of Zero and that's what makes the proton weightless.
