Force exerted by one disc on the other in a capacitor?
The problem involves two parallel circular disks, each with a specified area and uniform charge density, and seeks to compute the force exerted by one disk on the other. The context is within electrostatics, specifically dealing with electric fields and forces between charged objects.
  • Participants discuss the calculation of the electric field due to one disk and its effect on the other disk. There are attempts to clarify the relationship between the electric field and the force, as well as the implications of the distance between the disks.
Some participants have provided insights on the correct approach to calculating the force, emphasizing that the force on one plate is due to the electric field created by the other plate. There is ongoing exploration of the implications of the charge distribution and the electric field strength.
Participants note that the distance between the plates is not provided, which raises questions about its relevance to the calculations. There is also mention of potential errors in the calculations and the importance of using the correct electric field strength for the force calculation.
mot
Two circular disks, each of area 4.10×10-4 m2, are situated parallel to one another. The distance between them is small compared with their radii. Both disks are uniformly charged; their charges per unit area are σ = 5.00×10-5 C/m2 for one and -σ = -5.00×10-5 C/m2 for the other. Compute the force exerted by one on the other.
E=σ/ε
F=qE
E=σ/ε=5.00×10-5 C/m2/8.85x10-12
=5.649717514x106N/C
Charge on one plate = σ*Area=5.00×10-5 C/m2*4.10×10-4 m2=2.05x108C
F=qE=2.05x108C*5.649717514x106N/C
=0.1158N
I have tried both the positive and negative version of this answer, both are wrong. I have no idea what I'm doing wrong here...the distance between the plates isn't given, so I can't use coulomb's law (but they're not point charges anyways)
Help?
E=σ/ε
F=qE
=5.649717514x106N/C
=0.1158N
Help?
While the net field between the plates is the sum of the fields created by the charges on both of the plates, the force acting on one plate is due only to the field created by the other plate. That is, the field created by a given plate does not create a force on itself.
So. The field strength to use is that due to a single plate. That field will act on the charge on the other plate.
Sign error in exponent, but looks like this was just an error in copying out.
=0.1158N
That's what I get.
When two charged plates are very close, the field is essentially perpendicular to the plates. This means there is no attenuation with distance: the field is the same everywhere between the plates. The exact distance ceases to matter
Right, but the question asks for the force, not the field. The product of the charges will enter into it.
Yes, but the field due to one plate is due to the charge on that plate. So that charge is accounted for. Then F = Eq is the force on the other plate. The OP used the intermediate step of calculating E, so I did likewise.
Of course one can replace E by the expression involving the charge on a plate. Then product of the two charges emerges.
Mulled this over for a little while...got it! The field strength due to one plate is half as strong as the one calculated, and then I just used F=qE as normal to get my answer.
Thanks!
  • · Replies 21 ·
